I'm not sure how to explain this simply. Basically I have a repeat
group to break down a product into constituent components using values
derived from a CSV file (test.csv). Then I nest another repeat group
within the parent to break down each of the components into their active
ingredients, again using values pulled in from a CSV file (test-ai.csv).
The good news is it works. Everything looks like it should within ODK
Aggregate. The problem is when I publish to Google Fusion Tables where my
target audience will get the results from. Four Fusion Tables result,
which is fine. The trouble is the Table for the active ingredients, the
nested repeat group, only reports the results from the final repetition of
the group. I've been trying to find a way around this but I've been
stymied and publishing it into Fusion Tables is almost a necessity.
Below is the code. I don't have much hair left so I would be grateful
On Tue, Nov 29, 2016 at 4:01 PM, Greg wrote:
> Hello,
> derived from a CSV file (test.csv). Then I nest another repeat group within
> target audience will get the results from. Four Fusion Tables result, which
> is fine. The trouble is the Table for the active ingredients, the nested
> repeat group, only reports the results from the final repetition of the
> group. I've been trying to find a way around this but I've been stymied and
> for any ideas you may have.
> Thank you!
> <?xml version="1.0"?>
> xmlns:h="http://www.w3.org/1999/xhtml"
> xmlns:ev="http://www.w3.org/2001/xml-events"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns:jr="http://openrosa.org/javarosa"
> xmlns:odk="http://www.opendatakit.org/xforms">
> test
> 2
> 3
> <-- Parent group -->
> calculate="position(/test/Components)"/>
> calculate="concat(/test/ProductsList,'#',string(/test/Components/CompLoopNumb))"/>
> calculate="pulldata('test','fraction','Products_key',/test/Components/CompProdListNumb)"/>
> calculate="pulldata('test','ProductComponent','Products_key',/test/Components/CompProdListNumb)"/>
> calculate="/test/Amount * /test/Components/ProductMixFrac"/>
> <-- Nested group -->
> calculate="position(/test/Components/AI)"/>
> calculate="concat(/test/Components/ProductCompName,'#',string(/test/Components/AI/AILoopNumb))"/>
> calculate="pulldata('test-AI','ActiveIngredientName','ProductComponent_key',/test/Components/AI/AICompListNumb)"/>
> calculate="pulldata('test-AI','Guarantee','ProductComponent_key',/test/Components/AI/AICompListNumb)"/>
> calculate="/test/Components/ComponentPureAmount *
> /test/Components/AI/AIfrac"/>
> relevant="/test/LoopNumb = 10"/>
> Which product are you using:
> AA
> BB
> C_and_DC_and_D
> EE
> FF
> GG
> HH
> II
> JJ
> KK
> LL
> MM
> N_and_ON_and_O
> PP
> How much?
> Components Calc
> AI Calc
> Dummy field that doesn't do anything except make the loop
> work.
> work.
> "ODK Community" group.
