Hi!
I am trying to fill a form "Person" using eclipse in android emulator
(version 8). I am unable to display images on the form. Here are the steps I
tried.
- On Command prompt:
. "adb shell"
. "cd /sdcard/odk/forms/"
. "mkdir Person-media"
. "exit"
. "adb push logo.jpg /sdcard/odk/forms/Person-media/"
(the file copies and shows in the emulator's shell)
- On Debugging, the ODK Collect installs and executes fine. I downloaded my
form using "Manage Forms".
- The form opens but I don't receive any error message when I go to this
Logo widget.
The same happens with Videos as well. I thought it would be a file format
problem but "JPG" has to be supported anyway!
Please help me out.
Best Regards,
OWAIS AHMED
IRD Pakistan
Official: +922134327697
Personal: +923453174270
Skype: owais.a.hussain
Person.xml (2.36 KB)
your syntax is very incorrect. try this form...
http://cs.washington.edu/homes/yanokwa/tmp/Forest.zip
On Mon, Jul 25, 2011 at 05:54, Owais Hussain wrote:
> Hi!
> tried.
> . "adb shell"
> . "exit"
> Logo widget.
> Please help me out.
> Best Regards,
> OWAIS AHMED
> Software Engineer
> IRD Pakistan
> www.irdresearch.org
Hi Yaw!
I generated this XML from build.opendatakit.org. I see major differences
between the generated xml and this one. How do I do this through visual
designer (is there any for eclipse)?
Best Regards,
OWAIS AHMED
IRD Pakistan
On Mon, Jul 25, 2011 at 05:54, Owais Hussain owais.hussain@irdinformatics.org wrote:
Hi!
steps I
tried.
. "adb shell"
. "exit"
my
Logo widget.
Please help me out.
Best Regards,
OWAIS AHMED
IRD Pakistan
www.irdresearch.org
build currently supports only capturing multimedia. there is
currently, no visual designer that supports multimedia as part of the
prompt. if you are familiar with eclipse, you can probably look at the
xml and code it up by hand. the alternative is to wait a few days for
xls2xform which will allow you to design forms in excel.
On Mon, Jul 25, 2011 at 23:07, Owais Hussain wrote:
> Hi Yaw!
> Thanks,
> Best Regards,
> OWAIS AHMED
> Software Engineer
> IRD Pakistan
> www.irdresearch.org
>> > Hi!
>> > steps I
>> > tried.
>> > . "adb shell"
>> > . "exit"
>> > my
>> > Logo widget.
>> > format
>> > Please help me out.
>> > Best Regards,
>> > OWAIS AHMED
>> > Software Engineer
>> > IRD Pakistan
>> > www.irdresearch.org
Thanks Yaw! I already did it with eclipse and it works good.
Best Regards,
OWAIS AHMED
IRD Pakistan
On Mon, Jul 25, 2011 at 23:07, Owais Hussain owais.hussain@irdinformatics.org wrote:
Hi Yaw!
Best Regards,
OWAIS AHMED
IRD Pakistan
www.irdresearch.org
Hi!
steps I
tried.
. "adb shell"
. "exit"
downloaded
my
this
Logo widget.
format
Please help me out.
Best Regards,
OWAIS AHMED
IRD Pakistan
www.irdresearch.org
