I have an xls project form with repeat group ,it is uploaded correctly ,fill form using odk collect and data appear in fields ,when downloading the data from server as .csv I found an empty fields in every repeat group !!!
I don't find any issue like my problem.
You might need to provide a little more information on this issue.
Usually the repeat groups work either by splitting the repeated questions across several columns or else by splitting the data into multiple tables. You might need to upload a sample of the data export (with any sensitive information removed or replaced) or give some information about how you download the data.
