Dear Team
I want Question no. "Note_consent2" appear if in any repeat "QAB2_A" or "QAB2_B" is yes
Logic Test_mail.xls (85 KB)
My recommendation would be to add an additional calculation question into your repeat group which determines if either ${QAB2_A} or ${QAB2_B} is yes, and return 1 if so or 0 if not. Then, after your repeat group, you can use the sum() function to count all these results up; if the sum > 0 then in at least one of the repeat groups they answered yes to either of these questions, otherwise if sum = 0 then none of these were ever answered yes in any repeat iteration.
You can use a simple relevant expression on ${Note_consent2} to show/hide it depending on the sum.
can you plz explain it in xls??
inside repeat:
${isyes}: calculation = number(${QAB2_A}='yes' or ${QAB2_B}='yes')
after repeat:
${sum}: calculation = sum(${isyes})
${Note_consent2}: relevant = ${sum} > 0
[or something to the effect...]
It's working thank you very much
