Problem installing Aggregate on Mac OSX
I've tried several times to install ODK Aggregate unsuccessfully. There was an earlier post where the person had the same problem but there was no answer.
I get to point where the 'Terminal' opens and I am prompted for my Google email followed by password. I am able to input the email but when I can't type the password. After hitting return a short script runs and says END-SCRIPT-FAILURE. I attached a screen shot for your review.
I am running OSX 10.8.5. Should I upgrade to Mavericks?
Thanks in advance for your help.
-Jim
Jim,
The newest versions of ODK Aggregate require Java 7. You can find a
copy at http://www.java.com/download.
-Jim
