Hi Dan,
It should be working again.
The problem was with the MOPE_v1 form definition.
The database ended up with two entries for it when there should
only be one entry. This is a known issue. An initial fix was done
in 1.2, and further fixes have been done in the 1.3.x release.
However, the problem still occurs from time to time.
The earlier issues were due to rapidly clicking the Add-form
button, causing two uploads to be processed within 1-2 seconds of
each other. We seem to have fixed that issue.
The newest issues seem to be related to the 15-minute grace period
for changed forms. In your case, you uploaded the form once at
11:11:06, and again at 11:12:17 (70 seconds later). For some
reason, the second upload did not detect and update the record at
11:11:06, but instead created a second record.
The low frequency of this issue (~1 every 3 weeks) and the fact
that it occurs during revisions to the forms, and not during data
upload, has placed in on the 'nice to fix' list -- we are not actively investigating it.
On Wed, Aug 21, 2013 at 1:32 PM, dcontre fuzzy.c...@gmail.com wrote:
Great - thanks for your quick reply. I've invited you as a developer.
Is this problem the result of a mistake on my part, and something
that I can avoid in future? Or simply an inevitable glitch?
Dan
On Wednesday, August 21, 2013 7:35:09 PM UTC+2, Mitch Sundt wrote:
Invite me as a developer (
https://urldefense.proofpoint.com/v2/url?u=http-3A__code.google.co
m_p_opendatakit_wiki_AppEngineTroubleshooting&d=DwIBaQ&c=0u3nQZwm2He4OdaqbWh55g&r=esqndH_etIHpQ7iw90NwIgzhly0Tl3auqWD0XPDO0sE&m=eGP4tixqcFJGRcCsskx5qtLjiyZjHv7_nxDMQdP07PE&s=CPbqwdPfSXnEoQ3qcIhEyOuH8F9Glle5f-8v85dfp8M&e= ) and I can fix this issue.
Note that version 1.2 is very old. You should consider upgrading
(upgrading won't fix this issue).
See
https://urldefense.proofpoint.com/v2/url?u=http-3A__code.google.com_p_opendatakit_wiki_AggregateReleaseNotes&d=DwIBaQ&c=0u3nQZwm2He4OdaqbWh55g&r=esqndH_etIHpQ7iw90NwIgzhly0Tl3auqWD0XPDO0sE&m=eGP4tixqcFJGRcCsskx5qtLjiyZjHv7_nxDMQdP07PE&s=inscihFPJ-U5ZG7tBVQk6YgLKebEdW2dbyB2QA2_63Y&e= for upgrade steps.
Note that with recent changes in BigTables storage, you may begin
to see failures during the publishing or retrieving of data.
On Tue, Aug 20, 2013 at 11:32 PM, dcontre fuzzy.c...@gmail.com wrote:
Hi all,
After successfully testing ODK Aggregate, I am now encountering a
server problem, using the same version of ODK (1.2) and the same form(s).
When I try to login to my naxosarch.appspot.com instance, the
server goes into a loop, starting here:
https://urldefense.proofpoint.com/v2/url?u=https-3A__naxosarch.app
spot.com_Aggregate.html&d=DwIBaQ&c=0u3nQZwm2He4OdaqbWh55g&r=esqndH
ZjHv7_nxDMQdP07PE&s=6USOoHjz9yJD8Q1_d_6kMoDVG3cIyXHwq5Dwmy0XctA&e=
and then trying to load this:
spot.com_Aggregate.html-23submissions_filter___&d=DwIBaQ&c=0u3nQZw
P4tixqcFJGRcCsskx5qtLjiyZjHv7_nxDMQdP07PE&s=fN9IZHphyTDPwITRV60557
cNJOIEotpC_zi66aysDMQ&e=
Neither fully loads, and it just cycles between them, giving me no
ability to act at all. Trying to upload forms from a tablet also
produces an error.
I'm at a bit of a loss. Has anyone experienced this, and/or have
any suggestions?
Dan
Options:
https://urldefense.proofpoint.com/v2/url?u=http-3A__groups.google.
com_group_opendatakit-3Fhl-3Den&d=DwIBaQ&c=0u3nQZwm2He4OdaqbWh55g&
x5qtLjiyZjHv7_nxDMQdP07PE&s=NbOMWBUutd39g-igS7h56cc6_PNAESPnpgATvF
uiF3o&e=
Groups "ODK Community" group.
send an email to opendatakit...@googlegroups.com.
For more options, visit https://urldefense.proofpoint.com/v2/url?u=https-3A__groups.google.com_groups_opt-5Fout&d=DwIBaQ&c=0u3nQZwm2He4OdaqbWh55g&r=esqndH_etIHpQ7iw90NwIgzhly0Tl3auqWD0XPDO0sE&m=eGP4tixqcFJGRcCsskx5qtLjiyZjHv7_nxDMQdP07PE&s=0i2MpsQElV2bnvVM2cw_jUHQh64--IBr94qf6lQhX44&e= .
mitche...@gmail.com
Options:
uiF3o&e=
mitche...@gmail.com
