Hi, i have developed a form with repeats and when the data is exported as
xlxs or csv, the repeats are either exported as hyperlinks or the data is
stored in a seperate tab. Is there ay way i can merge the repeats with the
main data?
Thanks in advance.
If you use ODK Briefcase to export your data to CSV, you will end up with
multiple CSV files which you can then import into separate sheets of an
Excel workbook. You can then link across those sheets with the KEY /
PARENT_KEY fields.
main data?
Thanks in advance.
You might also consider setting up a Fusion Table publisher. We provide a
'flattened" view if your form only has one level of repeats.
PARENT_KEY fields.
main data?
Thanks in advance.
