The current version is still an issue on level 3 of cascading select. I've tried the solution in this forum, but it does not work. Level 1 and 2 selection works perfectly. This is an issue only in repeat group. In regular group, 3 levels work perfectly.
Please help !!! thanks in advance...
Do you mean that specieanimal is not showing you the options you expect? I tried your form in ODK Collect v1.24.0 and it works as I would expect. What version of Collect are you using?
Hi Helen,
Yes, the list of specieanimal does not shown as expected with laptop computer. But with smart phone is working fine. We want to make it work by using both plat forms: phone and latop.
Thanks a lot for reporting @rednoze, and for investigating @ln! This turned out to be a rather nasty bug, so I'm very relieved it's been eradicated forever now.
With android OS on smart phone, it works perfectly but not when we operate with Laptop or Desktop in web-based application on ONA online mode.
Our discussion is about how to make it work on both platforms, i.e: Phone and Laptop using XLSForm in offline or online mode.
The bug is:
The cascading select in repeat group does not work at third level, but it works in regular group.
Try this. URL: https://enketo.ona.io/x/#hzghY8cC . There, I created a form for testing with the cascading select in 2 groups: one in regular group and other one in repeat group.
At third level in repeat group, the list of animal specie does not show.
