What is the problem? Please be detailed!
I recently upgraded from 1.3.4 -> 1.4.2 -> 1.4.3 -> 1.4.4 -> 1.4.14 as described in https://github.com/opendatakit/opendatakit/wiki/Aggregate-Release-Notes#general-upgrade-steps.
Soon after logging in to ODK Aggregate after the update, I’m getting the error: Error: Problem persisting data or accessing data (Somehow DB entities for publisher got into problem state)
ODK Aggregate 1.4.14 on Google Cloud Platform.
Log into our server at https://pma2020gh.appspot.com/. If you would like to do that, let me know and I can provide credentials.
- Deleted all form definitions manually, except for one that will not delete.
- Purged all submissions up to some date in 2010, well before the server was ever created.
- Looked at logs and tried manual steps described at before running into an 'exception' (i.e. the tables I need to clear are not there) https://github.com/opendatakit/opendatakit/wiki/Aggregate-AppEngine-Troubleshooting#repairing-the-form-definition-table
After upgrading the server, we wanted to delete all data but keep our 'appspot.com' URL. Since there is no programmatic way to delete form submissions, we deleted those manually. We also purged submissions.
This error appears as a popup alert message on login, and as a flash message at the top of the screen after clicking ‘ok’ in that alert. It goes away if I navigate or refresh the page, but sometimes comes back.
There’s one form on the server I can’t delete, and some submissions showing which I also cannot delete for that form.
I've examined the logs, but they didn't appear helpful to me. I also examined 'error reporting' on google cloud (different module from 'logging') and saw the following error, which I'm not sure is related, but also occurred after upgrading the server: Type 'org.opendatakit.common.security.client.RealmSecurityInfo' was not assignable to 'com.google.gwt.user.client.rpc.IsSerializable' and did not have a custom field serializer.For security purposes, this type will not be serialized.: instance = org.opendatakit.common.security.client.RealmSecurityInfo@1edab541
I've posted the .json from the log related to the first error that is the topic of this post, as well as the stacktrace related to this RealmSecurityInfo error here in an open Github issue: https://github.com/opendatakit/opendatakit/issues/1106
I have also tried to follow the instructions for manual resolution found here: https://github.com/opendatakit/opendatakit/wiki/Aggregate-AppEngine-Troubleshooting#repairing-the-form-definition-table
However I am seeing that there are no "opendatakit._" (e.g. 'opendatakit._form_info_submission_association') namespaced tables on my server. I scrolled all the way to the bottom and none of them are there. The only kind of tables that appear are:
- _ah_SESSION
- _STRING_FIELD_LENGTHS_
- TASK_LOCK
- _COST_LOGGING_
- Many, many tables for what appear to be all form definitions, of a name like "opendatakit.<form_name>" where <form_name> is a form name string of character set [A-Z0-9_].
This leads me to believe that something went seriously wrong when the server was upgrading.
We would just delete the instance and create a new one, but then we would lose our URL ( pma2020gh.appspot.com
in this instance), as it appears that disabling/deleting an app takes 30 days, and we can't wait that long. All of our people who use this server are familiar with this URL, so we'd like to keep it.
