Wondering if any of you is using ODK Clinic v1.0 from the repo. I was trying to build and test the application but I got the following error (tested in both, emulator and tablet):
02-07 18:00:13.581: E/AndroidRuntime(296): FATAL EXCEPTION: main
02-07 18:00:13.581: E/AndroidRuntime(296): android.content.ActivityNotFoundException: No Activity found to handle Intent { act=org.odk.collect.android.action.FormEntry (has extras) }
Can you give me an idea where to start debugging this?
My guess is that you are using ODK Collect v1.1.7 which doesn't have
the same intent support that Collect v1.1.5 had. I've sent you some
files that I got from Sam Mbugua that should solve this problem.
On Tue, Feb 7, 2012 at 16:04, William Aviles Monterrey wrote:
> Hi all
> Best,
> William
Sent: Tuesday, February 07, 2012 9:26 PM
To:
Subject: Re: [ODK Community] Problem running ODK Clinic from source
On Tue, Feb 7, 2012 at 16:04, William Aviles Monterrey wravmon@yahoo.com wrote:
Hi all
trying
in
I am also getting the same following issue, let me know how to resolve this
I really want to use ODK collect platform with Open MRS but seems like they are going in their own direction. Can you please guide me the best way to get the benefits of bot the platforms
On Wednesday, February 8, 2012 8:56:32 AM UTC+5:30, Yaw Anokwa wrote:
The best approach will be to write a module in OpenMRS that implements
the OpenROSA API
(https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaAPI) and use
ODK Collect to talk to that module. Then to get OpenMRS data on the
device, create a standalone Android app that talks to OpenMRS' APIs
(e.g., to sync patient data). Then use Intents to connect OpenMRS data
with form filling in ODK Collect. There is nothing turnkey that does
what I've described so you'll have to write a fair bit of code.
Thanks for the response, but xforms module is already written in OpenMRS,
can that be reused with little bit of modifications.
or As you mentioned that you provide support and services for ODK, is your
company willing to take this kind of work as well openmrs and odkclinic
support.
Regards
Nidhi
the OpenROSA API
this
