Hello,
After reading through instructions for displaying an image in survey form,
I have made a media column (media::image) and saved .png files in the
sdcard folder. WHn I go to that question it says image is missing. I am not
sure what I am doing wrong. Any help please?
Rubana
Hi Rubana,
The error message in Collect should have given you a hint as to where
to put the images. They go in /odk/forms/[formname]-media.
If that still doesn't work, make sure the filenames of the image
itself and the filename you put in the form are an exact match.
On Sun, Apr 23, 2017 at 12:08 AM, Rubana Islam wrote:
> Hello,
> After reading through instructions for displaying an image in survey form, I
> have made a media column (media::image) and saved .png files in the sdcard
> folder. WHn I go to that question it says image is missing. I am not sure
> Thanks,
> Rubana
> "ODK Community" group.
Thanks a lot Yaw for your quick responses. The error message shows-
File:/storage/sdcard0/odk/forms....
I am using Samsung galaxy tab 2. I cannot see a storage/sdcard0 folder. I
have loaded the images to the odk/forms..... My question is is this feature
only possible when a sdcard is present?
Rubana
On Tuesday, April 25, 2017 at 1:53:07 AM UTC+10, Yaw Anokwa wrote:
> Hi Rubana,
> Yaw
> On Sun, Apr 23, 2017 at 12:08 AM, Rubana Islam <iru...@gmail.com > wrote:
> > Hello,
> form, I
> sdcard
> sure
> > Thanks,
> > Rubana
> Groups
> an
Hi Rubana,
If you are using ODK, it means the /odk folder exists on your device.
It might be internal storage. It might be external storage.
Samsung devices do strange things, so I can't tell you exactly where
that root path will be. Use your favorite Android File Explorer (e.g.,
https://play.google.com/store/apps/details?id=com.estrongs.android.pop)
to find it.
> Best,
> Rubana
>> Hi Rubana,
>> Yaw
>> > Hello,
>> > form, I
>> > sdcard
>> > sure
>> > Thanks,
>> > Rubana
>> > Groups
>> > an
>> > email to opendatakit...@googlegroups.com.
