I just updated Collect from 1.1.7 to 1.2 (1012). One thing I noticed is
that, when I enter a field response that leads to a skip in subsequent
questions (e.g. the respondent does not give consent, so the form skips to
end), swyping back does not revert to the original field (i.e. consent) but
instead to a grouped field somewhere after it. I can go back to the
(consent) question via the menu > go to prompt and selecting the field.
I've not logged this as an issue because I wondered if it is related to the
way Javarosa/1.2 works rather than a bug. This did not happen in previous
versions of Collect.
When you swipe backward from the end of the form, it should go to the first
relevant question or group as seen from stepping backward through the form.
So if this question is not relevant, then please open an issue, describe
how to reproduce, and attach a form with the problem (the simpler the
better).
