Problem when entering data with date format
Hello,
I add a variable (date format) using XLS2XForm:
add date prompt
When I try to enter data, I got this message: "The application ODK
Collecfty (process org.odk.collect.android) has stopped unexpectedly.
Please try again"
Can anyone help me?
Ibnou
Hi Ibnou,
I'm working on a new version of XLS2XForms which I'm hoping to make
available sometime this week. Hopefully your problem will go away in
the new version. If you could send me the spreadsheet, I will test it
out and send you the XForm back if it works. And if it doesn't work it
will help me figure out what the problem is.
-Nathan
ยทยทยท On Feb 6, 2:34 am, Ibnou DIENG wrote: > Hello, > > I add a variable (date format) using XLS2XForm: > > add date prompt > > When I try to enter data, I got this message: "The application ODK > Collecfty (process org.odk.collect.android) has stopped unexpectedly. > Please try again" > > Can anyone help me? > > Ibnou
