Problem with data not passing to fusion tables
Hi all
Just a little problem if you could help please.
I have setup up the whole process of collect, aggregate and fusion
tables and got it to work fine, but I have cleared all my old test
data and forms out and stated again with a new real form. The form is
working fine and it can push data through to aggregate and see each
form submission, and it then publishes to and creates a fusion table
file - but it has no data in it!
Any throughts on what I might be doing wrong, as I cant see anything
different from what I did before, I have tried publishing with all the
diferent options, tried adding new data through the form, left the
system alone for a couple of days to see if it just takes time, I have
increase my daily budget to see if it is a cost restriction - but
nothing - just looking at a fusion table with no data in it.
Help
Jon
What version of Aggregate are you using? There was a problem with one
of the releases (don't remember off hand) with publishing. Please
upgrade to the latest version 1.0.4. If that doesn't solve your
problem let us know.
Waylon
··· On Mon, Jan 16, 2012 at 10:54 AM, Jon Parsons wrote: > Hi all > > Just a little problem if you could help please. > > I have setup up the whole process of collect, aggregate and fusion > tables and got it to work fine, but I have cleared all my old test > data and forms out and stated again with a new real form. The form is > working fine and it can push data through to aggregate and see each > form submission, and it then publishes to and creates a fusion table > file - but it has no data in it! > > Any throughts on what I might be doing wrong, as I cant see anything > different from what I did before, I have tried publishing with all the > diferent options, tried adding new data through the form, left the > system alone for a couple of days to see if it just takes time, I have > increase my daily budget to see if it is a cost restriction - but > nothing - just looking at a fusion table with no data in it. > > Help > > Thanks > > Jon
Hi
I have understood a bit more now and upgraded using ODK Aggregate
v1.0.4 windows-installer.exe and created new fors and set up links to
publish to fusion and still face the same problem
help
thanks
Jon
··· On Jan 16, 8:12 pm, "W. Brunette" wrote: > What version of Aggregate are you using? There was a problem with one > of the releases (don't remember off hand) with publishing. Please > upgrade to the latest version 1.0.4. If that doesn't solve your > problem let us know. > > Waylon > > On Mon, Jan 16, 2012 at 10:54 AM, Jon Parsons wrote: > > Hi all > > > Just a little problem if you could help please. > > > I have setup up the whole process of collect, aggregate and fusion > > tables and got it to work fine, but I have cleared all my old test > > data and forms out and stated again with a new real form. The form is > > working fine and it can push data through to aggregate and see each > > form submission, and it then publishes to and creates a fusion table > > file - but it has no data in it! > > > Any throughts on what I might be doing wrong, as I cant see anything > > different from what I did before, I have tried publishing with all the > > diferent options, tried adding new data through the form, left the > > system alone for a couple of days to see if it just takes time, I have > > increase my daily budget to see if it is a cost restriction - but > > nothing - just looking at a fusion table with no data in it. > > > Help > > > Thanks > > > Jon
Hi
I have upgraded to ODK Aggregate v1.0.4 windows-installer.exe
but still no luck
help
Jon
Please only send one e-mail to one of the groups. Cross-posting is
confusing and not useful.
I'll treat this as the primary thread... copying response from other thread.
First, please upgrade to 1.0.4 and confirm that the problem still exists.
Streaming publishing had been broken; it might be the problem you're
experiencing.
To debug this yourself, look at the Logs for the instance to see what
errors are reported by the application. These are available via
https://appengine.google.com, under your application id, from the 'Logs'
link in the left sidebar.
If the problem continues to exist and you're on AppEngine, please invite me
as a developer to your instance and add me as a Site Admin (and let me know
what your instance is).
http://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
If you are using MySQL or PostreSQL, the logs are under the Tomcat logs
directory, in the catalina log file. Please open a new issue (
http://code.google.com/p/opendatakit/issues/list ) and attach the catalina
log for your system and I'll take a look at it.
··· On Tue, Jan 17, 2012 at 5:46 AM, Jon Parsons wrote:
Hi
but still no luck
help
Jon
Waylon
On Mon, Jan 16, 2012 at 10:54 AM, Jon Parsons j.pars...@globalcanopy.org wrote:
Hi all
Help
Jon
