I downloaded the latest jdk program and then tried to download aggregate. After the file was saved, it did not open an installation wizard. Rather it asked what program I wanted to open it with. Can you advise what I might have done wrong?
Lisa
Double-check that you downloaded the installer appropriate for your
operating system.
That is the only thing I can think of that would cause this problem.
What OS and version are you using?
You need to install the Java 7 before running the installer, but if it
isn't present, the installer should start up and then complain with an
error message.
Lisa
