benoist,
multiple questions per screen currently only works on the odk collect
1.1.7 beta. download it at
http://code.google.com/p/opendatakit/downloads/list.
yaw
On Tue, Jul 5, 2011 at 04:59, benoist Lambert wrote:
> Dear Sir,
> I have tried your application « ODK collect ».
> I have built my own form. I have some groups in my form and i have checked
> « Display on one screen » but it don’t works when i create a new record in
> my form on android tablet. Why ?
> Kind regards,
> Benoist L.
> ________________________________
> Ce message et toutes les pieces jointes (ci-apres le "message") sont
> confidentiels. Ce message est etabli a l'intention exclusive de ses
> destinataires. Toute utilisation ou diffusion non autorisee est interdite.
> Tout message electronique est susceptible d'alteration. FICAP decline toute
> responsabilite au titre de ce message s'il a ete altere, deforme ou
> falsifie.
> ___
> This message and any attachments (the "message") are confidential, intended
> solely for the addressee(s). Any unauthorised use or dissemination is
> prohibited. E-mails are susceptible to alteration. FICAP shall not be liable
> for the message if altered, changed or
> falsified.
from your device’s application drawer, choose settings, then
applications. make sure unknown sources is checked. also, if you have
1.1.5 installed, please uninstall it. finally, what device are you
using?
On Wed, Jul 6, 2011 at 01:05, benoist Lambert wrote:
> Hello,
> I have downloaded odk collect 1.1.7 beta but it doesn't works on Android 2.1. This apk doesn't install. Only odk collect 1.1.5 install correctly but the bug it doesn't fixed on this version :s
> Can you add this fix for android 2.1 ?
> -----Message d'origine-----
> De : Yaw Anokwa [mailto:yanokwa@gmail.com]
> Envoyé : mardi 5 juillet 2011 21:34
> À : benoist Lambert
> Cc : opendatakit@googlegroups.com
> Objet : Re: Problem with group and option "display on one screen" - ODKCollect on Android
> benoist,
> yaw
benoist,
sorry it's not working. i've filed a bug at
http://code.google.com/p/opendatakit/issues/detail?id=250 and we'll
get to it as soon as possible!
merci,
yaw
On Wed, Jul 6, 2011 at 08:56, benoist Lambert wrote:
> I have already checked "unknown sources" in this tablet and i have uninstalled 1.1.5 before installing 1.1.7 beta. My device is an Archos 7 HT on Android 2.1 .
> It doesn't install on this sdk platform.
> Benoist L.
> Envoyé : mercredi 6 juillet 2011 17:41
> À : benoist Lambert
> Objet : Re: Problem with group and option "display on one screen" -ODKCollect on Android
> from your device's application drawer, choose settings, then
> using?
>> Hello,
>> À : benoist Lambert
>> benoist,
>> yaw
> Ce message et toutes les pieces jointes (ci-apres le "message") sont confidentiels. Ce message est etabli a l'intention exclusive de ses destinataires. Toute utilisation ou diffusion non autorisee est interdite. Tout message electronique est susceptible d'alteration. FICAP decline toute responsabilite au titre de ce message s'il a ete altere, deforme ou falsifie.
> ___
> This message and any attachments (the "message") are confidential, intended solely for the addressee(s). Any unauthorised use or dissemination is prohibited. E-mails are susceptible to alteration. FICAP shall not be liable for the message if altered, changed or
> falsified.
