I'm trying to import data from one XML (instanceXML-29.xml, which I'm
attaching) into the form that I've created (formXML-29.xml, also
attached) using ODK-Voice, it does this using the code below
(FormLoader.java lines 64-76). I'm trying to get to a form which
looks like formXML-29-withData.xml, which basically populates with
fields given_name, family_name, patient_id, and dia_de_cumpleanos (day
of birthday).
If I have odk-voice use formXML-29-withData.xml the call is made as it
should, however, if it uses the xform where it uses the code below,
the call is made as though the the value readonly="true()" in the bind
is missing for the value given_name.
I'm trying to figure out if the data is being imported correctly or
not, but I can't figure out a way to see the final xml created after
the import using FormHandler, so I was hoping to get help in
- is the formatting of the xmls that I'm attaching correct, or could
that be the cause of the import error?
- how can I see the xml that is created after the import using FormHandler
- Any other ideas why this import might not be working.
I've talked with Adam Lerer about this and he suggested that I write
because this was getting into xforms and not so much ODK-Voice.
Joaquin
Code from ODK-Voice
if (instanceId != null) {
byte xml = dba.getInstanceXml(instanceId);
if (xml != null) {
log.warn("--- IMPORTING DATA FROM XML, FROM DATABASE FOR
INSTANCE ID: "+ instanceId);
fh.importData(xml);
} catch (SQLException e) {
log.error(e);
return null;
} finally {
dba.close();
InstanceXML-29.xml (3.39 KB)
formXML-29.xml (37.3 KB)
formXML-29-withData.xml (37.2 KB)
hi joaquin,
take a look at the formloadertask (around line 174) in the collect repo for an example of how we import instance data. you have to do all sorts of setup before you do the import. you might also have to update your core to the version we use in 1.1.7.
hope that helps,
yaw
of birthday).
Joaquin
Code from ODK-Voice
if (xml != null) {
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
<InstanceXML-29.xml><formXML-29.xml><formXML-29-withData.xml>
Thanks Yaw, I'll take a look at that. Is there a function to ouput the full
xml after importing to see what's going on?
J
hi joaquin,
hope that helps,
yaw
of birthday).
FormHandler
>> 3. Any other ideas why this import might not be working.
>> Thanks,
>> Joaquin
>> Code from ODK-Voice
>> byte[] xml = dba.getInstanceXml(instanceId);
>> if (xml != null) {
>> fh.importData(xml);
>> log.error(e);
>> return null;
>> } finally {
>> dba.close();
Thanks Yaw, and sorry, but I don't know what updating core to the
version in 1.1.7 means, could you expain it a bit more or point me to
somewhere where there's an explanation.
Joaquin
___________________________________________________________________
Gerente de Desarrollo, eHealth Systems
Research Fellow, Escuela de Medicina de Harvard
Moderador, GHDOnline.org
On Tue, Jun 7, 2011 at 9:04 AM, Yaw Anokwa yanokwa@gmail.com wrote:
hi joaquin,
hope that helps,
yaw
of birthday).
Joaquin
Code from ODK-Voice
if (xml != null) {
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
I think you can only output the instance data...
full
> J
>> hi joaquin,
>> hope that helps,
>> yaw
>>> of birthday).
>>> 1. is the formatting of the xmls that I'm attaching correct, or could
>>> 2. how can I see the xml that is created after the import using
> FormHandler
>>> Thanks,
>>> Joaquin
>>> Code from ODK-Voice
>>> if (xml != null) {
>>> fh.importData(xml);
>>> log.error(e);
>>> return null;
>>> } finally {
>>> dba.close();
somewhere in the odk voice code, there is a javarosa.jar that has all the processing logic. replace it with the latest one from the odk collect repo and you'll have updated the core.
Joaquin
hi joaquin,
hope that helps,
yaw
of birthday).
Joaquin
Code from ODK-Voice
if (xml != null) {
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
It's in war/WEB-INF/lib/javarosa-core.jar
Joaquin
hi joaquin,
hope that helps,
yaw
of birthday).
FormHandler
Joaquin
Code from ODK-Voice
if (xml != null) {
DATABASE FOR
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
Thanks, I had done that and gotten error messages that some of the
functions were not included in the newest libraries. Now, when I did
it again, I'm not getting those errors, so it might have been an
eclipse thing.
J
Joaquin
hi joaquin,
hope that helps,
yaw
of birthday).
FormHandler
Joaquin
Code from ODK-Voice
if (xml != null) {
DATABASE FOR
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
I'm continuing to work on getting the importData funcion to work. One
question, can the instanceXML (that has the data being imported into
the formXML) only have the form part of the XML, like shown below, or
must it be identical to the formXML i.e. include the binds and
selects?
If someone has examples of an XML that they imported as well as the
referenceXML to which they imported to, it'd be great.
Joaquin
On Wed, Jun 8, 2011 at 4:55 PM, Joaquín Blaya jblaya@ehealthsystems.cl wrote:
eclipse thing.
J
Joaquin
hi joaquin,
hope that helps,
yaw
of birthday).
FormHandler
Joaquin
Code from ODK-Voice
if (xml != null) {
DATABASE FOR
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
instances by definition should only the part of the form.
> selects?
> Joaquin
>> eclipse thing.
>> J
>>>> > Joaquin
>>>> > On Tue, Jun 7, 2011 at 9:04 AM, Yaw Anokwa wrote:
>>>> >> hi joaquin,
>>>> >> hope that helps,
>>>> >> yaw
>>>> >>> of birthday).
>>>> >>> FormHandler
>>>> >>> Thanks,
>>>> >>> Joaquin
>>>> >>> Code from ODK-Voice
>>>> >>> if (xml != null) {
>>>> >>> DATABASE FOR
>>>> >>> fh.importData(xml);
>>>> >>> log.error(e);
>>>> >>> return null;
>>>> >>> } finally {
>>>> >>> dba.close();
ok, should that include the instance tags within the xml?
selects?
Joaquin
eclipse thing.
J
Joaquin
hi joaquin,
hope that helps,
yaw
of birthday).
FormHandler
Joaquin
Code from ODK-Voice
if (xml != null) {
DATABASE FOR
fh.importData(xml);
log.error(e);
return null;
} finally {
dba.close();
if you save an instance in collect, you can take a look at the xml on
the sdcard. for something like geotagger, it looks like
<?xml version="1.0"?>
this is a instance with no image
>>> selects?
>>> Joaquin
>>>> eclipse thing.
>>>> J
>>>>>> > Joaquin
>>>>>> >> hi joaquin,
>>>>>> >> hope that helps,
>>>>>> >> yaw
>>>>>> >>> of birthday).
>>>>>> >>> FormHandler
>>>>>> >>> Thanks,
>>>>>> >>> Joaquin
>>>>>> >>> Code from ODK-Voice
>>>>>> >>> if (xml != null) {
>>>>>> >>> DATABASE FOR
>>>>>> >>> fh.importData(xml);
>>>>>> >>> log.error(e);
>>>>>> >>> return null;
>>>>>> >>> } finally {
>>>>>> >>> dba.close();
