Correct. There is something blocking the association of the MSHTA
application with this file extension. You might have an Anti-Virus
application that is blocking HTA applications from running.
If you have Windows 7, attached is a registry settings file from a
Microsoft support list that should reset the .hta associations back to
factory settings (i.e., the MSHTA executable). Download it and double-click
to run it. I've verified that the configuration on my computer exactly
matches the configuration that this file will set up for you.
Default_HTA.reg (1.8 KB)
On Thu, Apr 23, 2015 at 7:20 PM, Colin Beckworth wrote:Sent the directory path in an e mail as requested;
Tried the right click/open with/C:\Windows\SysWOW64\mshta.exe (I have a 64
bit machine - it thought about it for 10 minutes then gave the message "The
program you have selected cannot be associated with this file type. Please
choose another program."To make sure, I tried going in through the control panel to set default
program for opening .hta files, tried to change it to
:\Windows\SysWOW64\mshta.exe and got the same result. Just for
completeness, I tried the same things using C:\Windows\System32\mshta.exe,
again, same thingI'm pretty sure that before I changed the default program to IE, the icon
next to UploadAgregateToAppEngine was mshta. Am I correct in saying that
the problem I have is that mshta.exe for some reason isn't opening the .hta
file as it normally should? Perhaps are there other programs I could
download which can open .hta files?--
