Problem with odk build form saving
dear All, Greetings
when I build form with odk form builder, then it saves, and when I save it
in file, than it open blank, so, how to save the form and what we need to
open it
Regards
Hi there,
Your email doesn't have enough detail for us to help :frowning:
Can you please file an issue at
https://github.com/opendatakit/build/issues/new with the detailed
steps you are taking to get this behavior (e.g., what web browser are
you using, what prompts are you choosing, what is the minimum form
that has this problem)?
··· On Mon, May 22, 2017 at 6:08 AM, wrote: > dear All, Greetings > when I build form with odk form builder, then it saves, and when I save it > in file, than it open blank, so, how to save the form and what we need to > open it > Regards > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Dear YAW, thanks for your help
I should describe it with details.
I am new user of ODK, I could create app engine, its instances, and
finally ODK was installed on my PC and singed in, now, I tried to
build my form using form builder, I built it there and I saved it, but
there was not any browse to select storage of saving, so, now where
can I find my saved form and how??
thanks in advance
··· On 5/25/17, Yaw Anokwa wrote: > Hi there, > > Your email doesn't have enough detail for us to help :( > > Can you please file an issue at > https://github.com/opendatakit/build/issues/new with the detailed > steps you are taking to get this behavior (e.g., what web browser are > you using, what prompts are you choosing, what is the minimum form > that has this problem)? > > Thanks, > > Yaw > > On Mon, May 22, 2017 at 6:08 AM, wrote: >> dear All, Greetings >> when I build form with odk form builder, then it saves, and when I save >> it >> in file, than it open blank, so, how to save the form and what we need to >> open it >> Regards >> >> -- >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to a topic in the > Google Groups "ODK Community" group. > To unsubscribe from this topic, visit > https://groups.google.com/d/topic/opendatakit/EVPLjXK5-gg/unsubscribe. > To unsubscribe from this group and all its topics, send an email to > opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout. >
Hi Adil,
It sounds like you've used ODK Build to build a form, but you want to
know how to publish it to ODK Aggregate.
In the File menu of Build, you should have an option to Upload Form to
Aggregate. I've attached a screenshot.
··· On Tue, May 30, 2017 at 1:56 AM, adil mansour wrote: > Dear YAW, thanks for your help > I should describe it with details. > I am new user of ODK, I could create app engine, its instances, and > finally ODK was installed on my PC and singed in, now, I tried to > build my form using form builder, I built it there and I saved it, but > there was not any browse to select storage of saving, so, now where > can I find my saved form and how?? > thanks in advance > > On 5/25/17, Yaw Anokwa wrote: >> Hi there, >> >> Your email doesn't have enough detail for us to help :( >> >> Can you please file an issue at >> https://github.com/opendatakit/build/issues/new with the detailed >> steps you are taking to get this behavior (e.g., what web browser are >> you using, what prompts are you choosing, what is the minimum form >> that has this problem)? >> >> Thanks, >> >> Yaw >> >> On Mon, May 22, 2017 at 6:08 AM, wrote: >>> dear All, Greetings >>> when I build form with odk form builder, then it saves, and when I save >>> it >>> in file, than it open blank, so, how to save the form and what we need to >>> open it >>> Regards >>> >>> -- >>> -- >>> Post: opendatakit@googlegroups.com >>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >>> --- >>> You received this message because you are subscribed to the Google Groups >>> "ODK Community" group. >>> To unsubscribe from this group and stop receiving emails from it, send an >>> email to opendatakit+unsubscribe@googlegroups.com. >>> For more options, visit https://groups.google.com/d/optout. >> >> -- >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to a topic in the >> Google Groups "ODK Community" group. >> To unsubscribe from this topic, visit >> https://groups.google.com/d/topic/opendatakit/EVPLjXK5-gg/unsubscribe. >> To unsubscribe from this group and all its topics, send an email to >> opendatakit+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. >> > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
