A few weeks ago I installed the server and I had no problem, it worked wonders. but today I turned on the computer and when accessing the server appears to me that the page is not available.
try restarting apache tomcat and I do not have answer
I verify that the port 8080 being used by apache and not by another service.
and even so it's all right.
¿Has happened to anyone this before?
I will attach pictures showing the sequence when entering the server
Your network has probably assigned your computer a different IP address.
If you disconnect / turn off a computer for a while, when it is next
connected, the router / NAT device that is connects to will often issue a
different IP address than the one it assigned earlier.
You will want to configure your router / NAT device to issue a static IP
address to your computer.
And then you'll need to re-run the ODK Aggregate installer with that static
IP address so that everything links up as expected.
service.
