First I have problem with ODKBriefcase when downloading the data with
commandline, the process stop and shown the error below
"INFO: already present - skipping fetch:
uuid:964d1529-cb60-4bff-9a12-e7ef2a94a8f9
Nov 24, 2016 6:55:54 PM org.opendatakit.briefcase.util.ServerFetcher
downloadSubmission
uuid:59ab3c39-9745-40ab-b12a-c5c138ad3200
downloadSubmission
uuid:c359e99d-afb3-45c5-84dd-f4d576a7818d
downloadSubmission
uuid:88c6dc90-c8ad-4613-bfbf-f3753f54d144
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:170)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at
org.apache.http.impl.io.SessionInputBufferImpl.streamRead(SessionInputBufferImpl.java:139)
at
org.apache.http.impl.io.SessionInputBufferImpl.fillBuffer(SessionInputBufferImpl.java:155)
at
org.apache.http.impl.io.SessionInputBufferImpl.readLine(SessionInputBufferImpl.java:284)
at
org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:140)
at
org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:57)
at
org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:261)
at
org.apache.http.impl.DefaultBHttpClientConnection.receiveResponseHeader(DefaultBHttpClientConnection.java:165)
at
org.apache.http.impl.conn.CPoolProxy.receiveResponseHeader(CPoolProxy.java:167)
at
org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:272)
at
org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:124)
at
org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:271)
at
org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88)
at
org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at
org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
at
org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at
org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55)
at
org.opendatakit.briefcase.util.AggregateUtils.httpRetrieveXmlDocument(AggregateUtils.java:303)
at
org.opendatakit.briefcase.util.AggregateUtils.getXmlDocument(AggregateUtils.java:239)
at
org.opendatakit.briefcase.util.ServerFetcher.downloadAllSubmissionsForForm(ServerFetcher.java:294)
at
org.opendatakit.briefcase.util.ServerFetcher.downloadFormAndSubmissionFiles(ServerFetcher.java:178)
at
org.opendatakit.briefcase.util.TransferFromServer.doAction(TransferFromServer.java:43)
at org.opendatakit.briefcase.ui.BriefcaseCLI.run(BriefcaseCLI.java:182)
at
org.opendatakit.briefcase.ui.MainBriefcaseWindow.main(MainBriefcaseWindow.java:184)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at
org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Nov 24, 2016 6:56:54 PM org.opendatakit.briefcase.util.AggregateUtils
SEVERE: Fetch of submission download chunk failed. Detailed error:
Unexpected java.net.SocketTimeoutException: Read timed out "
Second, When login conecting with the server, not respon and shown this
error
"Unable to fetch formList: Unexpected java.net.SocketTimeoutException: Read
timed out"
Your connection to the server is timing out because your connection is
not fast or reliable.
If you can't improve your connection, you might want to consider
running Briefcase on the server, then move the data down to your
machine using some other protocol (e.g., rsync).
On Tue, Nov 29, 2016 at 5:10 AM, Rashida Lara wrote:
> Hi ODK Developer,
> 1. First I have problem with ODKBriefcase when downloading the data with
> downloadSubmission
> downloadSubmission
> downloadSubmission
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 2. Second, When login conecting with the server, not respon and shown this
> error
> timed out"
> What the problem??
> Thanks Before
> Sukarno
> "ODK Developers" group.
> email to opendatakit-developers+unsubscribe@googlegroups.com.
