eIMCI.xml - "HTTP Status 400 - Problem parsing submission XML Field
name: imci/Meta/formName appears to be a value field (it has no fields
nested within it) but does not have a type."
Geo Tagger.xml - "HTTP Status 400 - Problem parsing submission XML
Field name: geotagger/DeviceId appears to be a value field (it has no fields
Household Survey.xml - "HTTP Status 400 - Problem with JavaRosa Parsing
Form:xmlns attribute for the data model is not well-formed:
'HouseholdSurvey1' should be of the form
xmlns="http://your.domain.org/formId" Consider defining the formId using the
'id' attribute instead of the 'xmlns' attribute (id="formId")"
mediaform.xml: "HTTP Status 400 - Form did not specify a Form ID. For
information on Form ID please check the Open Data Kit FAQ"
Widgets.xml"HTTP Status 400 - Problem with JavaRosa Parsing Form:xmlns
attribute for the data model is not well-formed: 'widgets' should be of the
form xmlns="http://your.domain.org/formId" Consider defining the formId
using the 'id' attribute instead of the 'xmlns' attribute (id="formId")"
Given that so many of the sample forms broke for me I am wondering whether
there's something wrong with my setup. I am on my own machine (Ubuntu Linux)
with tomcat and MySQL. For the forms that did work I've been able to
download them to Collect and submit data back.
Also, is there a way to import them into odkbuild to see how they were built
in there - I'm looking for examples of how to do validation or more complex
things with the ODKBuilder. But when I tried it needs a .odkbuild file.
Many thanks in advance for your assistance.
Feel free to write back with a link if this is already somewhere and I've
missed it (and sorry in advance if that's the case).
sorry that you are having problems. there have been changes to
aggregate that make parsing more rigorous than it has been in the
past. i think this is probably the wrong approach and i've filed a bug
at http://code.google.com/p/opendatakit/issues/detail?id=283.
for now, i've fixed geotagger, household survey, and widgets. eimci
and mediaform will take much longer to fix, so i've removed them for
now. note that you can try out forms with newer features at http://opendatakit.appspot.com.
yaw
On Fri, Jul 29, 2011 at 18:48, Bird wrote:
> Hi all,
> Apologies if I've missed an existing post on this, I have had a look around
> and couldn't seem to see anything.
> I was trying to import all the sample forms from
> here: http://code.google.com/p/opendatakit/source/browse?repo=forms
> into my aggregate instance to have a look at ODK's capabilities.
> I am having an issue with a number of forms:
> eIMCI.xml - "HTTP Status 400 - Problem parsing submission XML Field name:
> imci/Meta/formName appears to be a value field (it has no fields nested
> Geo Tagger.xml - "HTTP Status 400 - Problem parsing submission XML Field
> Cheers,
> Bird
Is there also a way to import the forms into ODK Build so I can see how
they were developed in the builder?
Many thanks,
Sarah Bird
On Mon, Aug 1, 2011 at 2:54 PM, Yaw Anokwa wrote:
hi sarah,
Hi all,
around
the
the
whether
Linux)
built
complex
Cheers,
Bird
unfortunately, no. most of those forms were coded up by hand. you may
have better luck importing into purcforms
(http://code.google.com/p/purcforms/)
On Mon, Aug 1, 2011 at 15:09, Sarah Bird wrote:
> Thanks Yaw, that's great.
> Many thanks,
> Sarah Bird
>> hi sarah,
>> yaw
>> > Hi all,
>> > around
>> > name:
>> > the
>> > the
>> > whether
>> > Linux)
>> > built
>> > complex
>> > I've
>> > Cheers,
>> > Bird
Many thanks,
Sarah Bird
Hi all,
around
name:
nested
Field
Parsing
using
the
of
the
formId
(id="formId")"
whether
Linux)
built
complex
file.
I've
Cheers,
Bird
when you create a group, you can drag and drop other prompts inside to
get them to appear together (this only works with collect 1.1.7). you
can also make that group repeat. anything else that's not clear?
finally, we are also on the verge of releasing a new design tool that
should make form design a little easier.
On Mon, Aug 1, 2011 at 15:25, Sarah Bird wrote:
> No problem at all, thanks.
> Is there a guide somewhere to using the more advanced elements
> Relevance
> Specify a custom expression to evaluate to determine if this field is shown.
> Constraint
> Specify a custom expression to validate the user input.
> Instance Destination
> Specify a custom XPath expression at which to store the result.
> as well as the Group and Branch features of ODK Build.
> Many thanks,
> Bird
>> > Many thanks,
>> > Sarah Bird
>> >> hi sarah,
>> >> yaw
>> >> > Hi all,
>> >> > around
>> >> > name:
>> >> > nested
>> >> > Field
>> >> > fields
>> >> > Parsing
>> >> > using
>> >> > the
>> >> > Form:xmlns
>> >> > of
>> >> > the
>> >> > formId
>> >> > (id="formId")"
>> >> > whether
>> >> > Linux)
>> >> > were
>> >> > built
>> >> > complex
>> >> > file.
>> >> > I've
>> >> > Cheers,
>> >> > Bird
how
Many thanks,
Sarah Bird
bug
Hi all,
look
around
name:
nested
Field
fields
Parsing
using
the
For
Form:xmlns
be
of
the
formId
(id="formId")"
whether
(Ubuntu
Linux)
to
were
built
complex
file.
and
I've
Cheers,
Bird
