Problems opening Aggregate 1.4.5 OSX installer
I've downloaded the Aggregate 1.4.5 OSX inataller but it won't open on my computer. I'm getting the attached error message. Any suggestions would be great.
Overview: I'm running a large household survey in Uganda and wasn't using Briefcase or Aggregate (I've been uploading surveys every night) but I'd like to use these as backup, especially for the ability to de-duplicate surveys in Aggregate. I am sure I don't have a good grasp of how Briefcase and Aggregate work, so any other very simple step-by-step explanatory materials would be great, if someone could point me in good directions. Many thanks.
The downloaded file should be 152,552,817 bytes in size (145 MB).
After downloading the zip, it may be useful to open a Finder and expand the
zip from within that rather than launchingfrom within your browser. It may
be that the browser is not handling the spaces in the name correctly.
Did you follow these instructions (e.g., installing Java 7):
great.
Many thanks.
