I just bought a tablet and I am trying to install ODK in order to use the
application to collect and manage data for my thesis.
I am trying to install the ODK app and when I have to install ODK
aggregate, I have problems to install the "ODK aggregate v.1.4.". I try to
download the file but it does not work. It is the point 5 of the part
"Create an AppEngine Instance" in this tutorial.
I am transfered to a website with a list including all the files to be
downloaded (for linux, windows, osx...). Since the operative system is
android, I tried to download the linux versions but they didn´t work. I
also tried the windows and osx versions and it didn´t work either. All I
could do is downloading a file that is opened as a text file with
unrecognizable characters, but never a file to be executed and installed.
I have tried several times and I could not get it installed. Anyone could
give me some advice on how to do it?
Once you download the latest installer that is appropriate for your
operating system, you just need to double-click it and it should run,
presenting a Wizard-style installer interface.
On Thu, Nov 21, 2013 at 8:51 AM, sergio martin wrote:
Hello,
thanks a lot for your answer. I had seen that tutorial as well, but I chose
the other because I had the chance to change it into Spanish.
I am trying to install the file the way it is suggested in this tutorial.
But the problem is that the website listing all the files to be downloaded
is the same website suggested in the old tutorial. So when I download any
file, the only I get is a text document with weird symbols, most of them as
chinese characters. I am trying the 2 versions od "ODK Aggregate v.1.4"
that can be downloaded with linux, which should be executable files (.run)
and it is the same with both of them.
Do you have any idea why this can be?
Thanks.
2013/11/21 Mitch Sundt
That is a very old tutorial! The Aggregate installation portion is
completely out-of-date.
ODK Aggregate is intended to be run on an x86 system -- either MacOSX,
Linux, Linux-64bit, or Windows.
You cannot run it on the Android Tablet.
On Thu, Nov 21, 2013 at 12:59 PM, sergio martin wrote:
Hi Mitch,
chose the other because I had the chance to change it into Spanish.
the application to collect and manage data for my thesis.
could give me some advice on how to do it?
Groups "ODK Community" group.
I was afraid that it was an incompatibility problem or something like
that... but it seems weird to me. In the different tutorial videos I have
watched, they are using mobile phones to collect the data and it works.
What I need to do is using the tablet to collect the data (that´s the
reason because I bought it) even if I have to store the information in the
memory card and then download it in to a computer (with aggregate installed
in it?).
If this solution is very complicated, do you know any other program similar
to ODK I can use in my tablet? I was pretending to use ODK because I won´t
have internet connection while collecting the data and ODK allows storing
the info in the own tablet and download it when I have connection.
Thanks.
2013/11/22 Mitch Sundt
Re-reading your first e-mail more carefully ---
I think there is a fair bit of confusion here. To use ODK, you need to
do three things -- design a form, setup a server, and connect the
mobile device to that server. Once those three things are done, you'll
be ready to start data collection.
You'll need three tools:
ODK Build -- to design your survey form. XLSForm works too.
ODK Collect -- running on an Android device to download and fill-in the survey.
ODK Aggregate -- for hosting the survey form and gathering the survey
results. Briefcase works too if you want a simpler solution that works
on your desktop computer.
watched, they are using mobile phones to collect the data and it works. What
I need to do is using the tablet to collect the data (that´s the reason
because I bought it) even if I have to store the information in the memory
card and then download it in to a computer (with aggregate installed in
it?).
chinese characters. I am trying the 2 versions od "ODK Aggregate v.1.4" that
can be downloaded with linux, which should be executable files (.run) and it
android, I tried to download the linux versions but they didn´t work. I also
tried the windows and osx versions and it didn´t work either. All I could do
is downloading a file that is opened as a text file with unrecognizable
yes Yaw, I´m not an expert in computers and there is a lot of confusion in
my head Thanks a lot for your advices. I´m trying to get this app
because I am supposed to be able to store the data directly in my tablet
and that is what I need.
I could create the form (build) and install the collect tool in my tablet.
I just could install the App Engine (Aggregate) today and in my computer
(windows), not in the tablet. That is a great advance because I was blocked
there for a few days. Nevertheless, I am trying to export the form I
created to ODK aggregate "add new form+upload form" and I get a message
informing that I can´t upload the form in aggregate, so I cant open it and
collect the data.
This is the message, any idea how I can overcome it?:
Error: Problem with JavaRosa Parsing Form:
org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa
failed to construct a FormDef. Is this an XForm definition?
Thanks a lot.
2013/11/22 Yaw Anokwa
Sergio,
survey.
What
memory
it?).
similar
won´t
tutorial.
downloaded
any
them as
v.1.4" that
and it
try to
be
is
work. I also
could do
unrecognizable
send
because I am supposed to be able to store the data directly in my tablet and
I could create the form (build) and install the collect tool in my tablet. I
there for a few days. Nevertheless, I am trying to export the form I created
to ODK aggregate "add new form+upload form" and I get a message informing
that I can´t upload the form in aggregate, so I cant open it and collect the
data.
survey.
have
What
memory
it?).
similar
won´t
storing
tutorial.
downloaded
any
them as
v.1.4" that
and it
use
try to
part
be
is
work. I also
could do
unrecognizable
send
That´s the way I´m doing it, exporting it as XML and then trying to upload
it from Aggregate... I also tried to export the form directly from build to
Aggregate (file- Publish to aggregate) but I also get an error.
2013/11/23 Yaw Anokwa
Sergio,
That error suggests that you are not uploading a valid XForm to
Aggregate. From Build, export the form as XML and upload that to
Aggregate.
in
app
and
tablet. I
blocked
created
the
data.
survey.
have
works.
What
reason
memory
in
it?).
similar
won´t
storing
I
tutorial.
downloaded
download
any
them as
v.1.4" that
(.run)
and it
run,
use
I
try to
part
to
be
system
is
work. I also
I
could do
unrecognizable
Anyone
send
Sorry you are having problems. Try running the form through ODK
Validate (http://opendatakit.org/use/validate). Does it offer a more
useful error message?
in
app
and
tablet. I
blocked
created
informing
the
data.
Javarosa
survey.
have
works.
What
reason
memory
in
it?).
similar
won´t
storing
I
tutorial.
downloaded
download
any
them as
v.1.4" that
(.run)
and it
your
run,
use
I
try to
part
to
be
system
is
work. I also
I
could do
unrecognizable
Anyone
You received this message because you are subscribed to the
Google
send
I used the link you suggested and the form kept failing, so I did the form
again step by step to check where the problem was and I may have done
something different because it seems to work now.
I was also proving the form and I could publish the data into a google
spreadsheet. I could see that the data registered in the spreadsheet is the
underlying value, with the "_" symbol. Since the data is going to be
included in my theses (probably as an excel spreadsheet or Acess files) I
was wondering if there is a chance that the information recorded is
displayed as shown in the form (the one in the field called English, not
the underlying value in http://build.opendatakit.org/).
I saw that I can keep the forms stored in my device and send them later
when I have internet connection, which is what I was looking for.Thanks for
your ideas and congratulations for your project, I think it will be very
useful for my data collection.
I also would like to know if there is the chance to make something a bit
more complicated with build or I need to change to another program. For
example, if the answer to one question is A, then you can choose from
options 1 and 2, is the answer is B, then you can choose options 3 and 4.
Thanks in advance.
Sergio,
upload
to
confusion
in
app
tablet
and
tablet. I
blocked
created
informing
collect
the
data.
Javarosa
to
you'll
the
survey.
works
like
I
have
works.
What
reason
memory
installed
in
it?).
similar
I
won´t
storing
but
I
Spanish.
tutorial.
downloaded
download
any
of
them as
v.1.4" that
(.run)
and it
your
run,
to
use
ODK
v.1.4.".
I
try to
the
part
files
to
be
system
is
work. I also
All
I
could do
unrecognizable
Anyone
Google
it,
send
You can add logic/branching in Build, but I'd recommend you try http://opendatakit.org/use/xlsform instead. It's a little harder to
use, but it gives you more a lot more power.
XLSForm will also give the option to use the label in the final
output. You'll have to use a calculate. If for example you have list
of selects called my_list. You can make a calculate/hidden prompt
called my_list_label (or something similar). If you put the following
in the calculate column, it will have the value of the label.
if(string-length(${my_list}) !=
0,jr:choice-name(${my_list},'${my_list}'),'(Unknown item from
my_list)')
displayed as shown in the form (the one in the field called English, not the
I saw that I can keep the forms stored in my device and send them later when
I have internet connection, which is what I was looking for.Thanks for your
ideas and congratulations for your project, I think it will be very useful
upload
to
confusion
in
this
app
tablet
and
tablet. I
computer
blocked
created
informing
collect
the
data.
Javarosa
to
you'll
the
survey.
survey
works
like
I
have
works.
What
reason
the
memory
installed
in
it?).
program
similar
I
won´t
storing
but
I
Spanish.
tutorial.
downloaded
download
any
of
them as
v.1.4" that
(.run)
and it
your
should
run,
to
use
ODK
v.1.4.".
I
try to
the
part
files
to
be
system
is
didn´t
work. I also
All
I
could do
unrecognizable
Anyone
Google
it,
send
