We're having some trouble uploading a form created on the build.opendatakit.org site to our appspot aggregate instance.
The error we get is this: {"error":"Something went wrong when trying
to post to Aggregate."}
We're not uploading too complicated a form, and in fact very simple
forms are not uploading either. I understand that some work was being
done on the build.opendatakit server recently, but it doesn't look
like it has fixed this problem.
I'm happy to provide any information necessary to help get this fixed.
What is your build username, and the name of the build form you are trying to upload?
—Clint Tseng
On Tue, Mar 1, 2011 at 12:13, Clint Tseng wrote:
> Hi Satadru:
> Thanks,
> —Clint Tseng
>> Regards,
>> Satadru
Also make sure you are using Aggregate 0.9.4. No other versions of
Aggregate support posting the forms from Build.
On Tue, Mar 1, 2011 at 9:26 AM, Satadru Pramanik wrote:
> build username: satadru
> form name: CCNYTest7
>> Hi Satadru:
>> Thanks,
>> —Clint Tseng
>>> Regards,
>>> Satadru
Aah! I'm using the 1.0 version... Going forward, when should we
expect compatibility with 1.x?
>>> Hi Satadru:
>>> Thanks,
>>> —Clint Tseng
>>>> Regards,
>>>> Satadru
The functionality will be added when Aggregate 1.0 is officially
released which is scheduled to happen around the first of April. Right
now Aggregate is0 in the alpha stage, it will then move to beta, then
it will be released. In alpha we are letting people play with it and
give feedback while we are moving ahead with other parts of the
development. The whole security model of Aggregate is changing and
build will migrate to that security model once it's complete.
Waylon
>>>> Hi Satadru:
>>>> Thanks,
>>>> —Clint Tseng
>>>>> Regards,
>>>>> Satadru
Until support is added to Aggregate 1.0, you will need to Export to XML from
Build then upload the form manually into Aggregate.
Waylon
