Hi folks,
I installed Aggregate 1.0 and the installation worked well (using the
template) but when i run in my appspot the pages not works as well,
looks like always in refresh and i can't use.
Someone had this problem?
thanks a lot
Hi folks,
thanks a lot
Hi Renan,
Sorry you're having problems; thank you for reporting the issue.
I've created issue http://code.google.com/p/opendatakit/issues/detail?id=245
to track the problem; I believe I've identified the root cause.
What browser are you using; what version?
If you have a lot of browser windows open, or have pages open to many sites
that continually refresh their web pages with animations, news feeds, IRC or
the
like, or if you are doing something else on the computer that bogs it down,
you
are more likely to encounter the issue I've identified.
A temporary work-around that should work is to close extraneous browser
windows, or to run an entirely different browser for accessing Aggregate
beta rev. 2 (e.g., access our site with Chrome or IE of you use Firefox for
all your other browsing).
If those work-arounds don't work, please let me know.
We will have a fix in the next release that won't require any of these
work-arounds.
Thanks again,
Hi folks,
looks like always in refresh and i can't use.Someone had this problem?
thanks a lot
Renan A. Kamimura--
Hi Mithc, sorry for the delay.
I saw the Issue 245. Thanks a lot for pay attention!!!
Well, i'm using CHROME 11.0.696.65. i tested too in IE 8.
But the Aggregate don't works, continue with the same problem.
The tests were done with one by one browser, without other open pages
or sites and without others functions in computer.
May be a problem from my computer?
Have another way to solve?
thanks
Renan
Renan A. Kamimura
