Hi folks !!!
I'm using Kobo post processor to deploy some data from ODK Collect 1.1.7.
The problem is the instance when exported to .csv the data aren't
dissociated with comma ...
all questions are in the same column.
someone had this problem or could help?
Attached the Xform that i used.
thanks for help!!!
Matriz_simples.xml (10 KB)
Renan A. Kamimura
Renan,
I think you've just mis-named your fields. The Post Processor will seperate
Multi selects into discrete fields if "_MULTI" is appended to the node name
in the instance. This is the only way that KoBoPP can tell the difference
between a multi select and a text field.
All the details are here:
http://code.google.com/p/kobo/wiki/KoBoPPMultiSelect
Let me know if I can be of further help.
☞§※☼:airplane:
Neil Hendrick
2011/7/28 Renan Kamimura
Hi folks !!!
thanks for help!!!
Renan A. Kamimura
Renan,
You might also send along some completed XML files and your CSV output if
you want me to take a look at it.
~Neil
Hi Neil ... i've attached the .csv file and Xform.
Thanks a lot!
Renan
Sementes.csv (322 Bytes)
2011/7/28 Neil Hendrick
Renan,
~Neil
Renan A. Kamimura
Renan, could you send me a completed survey instance?
☞§※☼:airplane:
~Neil
Thanks a lot!
Renan
2011/7/28 Neil Hendrick mojotexas@gmail.com
Renan,
~Neil
Renan A. Kamimura
Sorry Neil.
Atacched
Matriz_simples_2011-07-28_15-15-59.xml (637 Bytes)
Matriz_simples_2011-07-28_15-15-18.xml (631 Bytes)
☞§※☼:airplane:
~Neil
2011/7/28 Renan Kamimura renankami@gmail.com
Thanks a lot!
Renan
Renan,
~Neil
Renan A. Kamimura
Renan A. Kamimura
OK, Renan, looks to me like you are nesting your instances one level too
deep. It's like you are treating your whole survey as if it were a nesting
group. A) That's not necessary, and B) KoBoPP doesn't support groups.
Your instance looks like this:
<model>
<instance>
<Sementes id="sementes">
<Matriz>
<N_matriz/>
You should dump Matriz, like this:
<model>
<instance>
<N_matriz/>
☞§※☼:airplane:
~Neil
Sorry Neil.
Atacched
☞§※☼:airplane:
~Neil
Thanks a lot!
Renan
Renan,
if you want me to take a look at it.
~Neil
Renan A. Kamimura
Renan A. Kamimura
Neil ... thanks a lot!! It's OK, the problem is solved!!!
Another doubt... It's possible that the questions into .csv appear in the
same sequence from Xform ?
Sorry for the simple questions and errors cause i'm don't a developer!!! I'm
begginer!
Renan
<model>
<instance>
<Matriz>
<N_matriz/>
<model>
<instance>
<N_matriz/>
☞§※☼:airplane:
~Neil
Sorry Neil.
Atacched
☞§※☼:airplane:
~Neil
Thanks a lot!
Renan
Renan,
~Neil
Renan A. Kamimura
Renan A. Kamimura
Renan A. Kamimura
Renan,
Good questions all of them, and always welcome.
Glad your problem is solved.
You noticed that the fields show up in your CSV in a kind of random order.
That is true, it is because the Post Processor is opportunistic in
aggregating data, and so the CSV shows up like that.
You can handle it the same way we handle it.
Open your CSV in Excel, copy and Paste Special all the data into a new
worksheet. When you Paste Special, check the option to Transpose.
This will invert your data so that the columns and rows are switched. It's
like pasting sideways.
Now you can sort the columns alphabetically (or some other way).
Copy and Paste Special with Transpose again, in a new worksheet.
So, that's how you sort your data. Hope that helps.
☞§※☼:airplane:
~Neil
On Thu, Jul 28, 2011 at 4:53 PM, Renan Kamimura wrote:
It's possible that the questions into .csv appear in the same sequence from
Xform ?
