in the last 3 days I have been trying to download the results of my surveys with ODK Briefcase version 1.4.3 and version 1.4.4. With both of the versions, once I enter the link to the Aggregate cloud, the user and the pass, the following message appears and I fail to pull the data:
"Accessing the server failed with error: Exception: The server has not provided an available-forms document compliant with the OpenRosa version 1.0 standard."
Can any of you help me understand whether the problem is within my Aggregate or with ODK Briefcase?
Also a colleague of mine has experienced the same issue, and we both are using the same Aggregate.
Also, if you are accessing this via wifi, you might have been redirected to
a wifi terms / login screen (e.g., at Starbucks). To get past that, try
opening a browser to your aggregate server. Once you clear any login /
authorization screens, you should be able to use ODK Briefcase.
Is your ODK Aggregate running on AppEngine or elsewhere?
What version ODK Aggregate are you using?
On Tue, Dec 2, 2014 at 12:43 AM, wrote:
Hello ODK Developers,
1.0 standard."
