I'm new to ODK but after doing a fair bit of googling I can't find a
solution, so I figured I'd ask here. I have an application that needs to be
able to programmatically retrieve data from an instance of ODK Aggregate.
Ideally this would be done on an automated schedule, so having a way to get
the delta of submissions since last retrieval would be great. The data can
be in any format - JSON, XML, CSV, whatevs.
I've seen that there have been some mentions of publishing the data from
Aggregate to Google Fusion Tables, and then accessing the data through
Google's API, but that seems pretty Rube Goldberg-ish. I've also read that
ODK supports something called the OpenRosa API, but the terminology in that
documentation is confusing and I'm not sure if it provides the
functionality I'm looking for - advice would be appreciated here. Also,
I've seen ODK Briefcase, but as this is a standalone jar that still needs
to be triggered manually, it pretty much defeats my purpose.
Surely there has to be some way to do this - looking forward to your
suggestions.
On Tue, Nov 5, 2013 at 1:27 PM, Alan DeLong wrote:
Hi all,
suggestions.
Thanks Mitch, the JSON publisher seems to be exactly what I'm looking for.
The ODK instance the organization is running will require an upgrade and
then we should be all set.
Cheers,
Alan
On Tuesday, November 5, 2013 8:34:15 PM UTC-5, Mitch wrote:
> There are several other options:
> (1) if you have a server, you could set up a publisher (e.g., JSON
> publisher) in ODK Aggregate to stream data to that server. See
> http://code.google.com/p/opendatakit/wiki/AggregateToJSonXmlREDCapPublishers
> (2) you can use ODK Briefcase to download the contents of ODK Aggregate,
> emit a CSV and load that into your app.
> (3) your app could implement the functionality of ODK Briefcase to access
> the data directly from ODK Aggregate. See
> http://code.google.com/p/opendatakit/wiki/BriefcaseAggregateAPI
> On Tue, Nov 5, 2013 at 1:27 PM, Alan DeLong <aland...@gmail.com wrote:
>> Hi all,
>> suggestions.
>> Thanks,
>> Alan
>> "ODK Developers" group.
>> email to opendatakit-developers+unsubscribe@googlegroups.com
>> For more options, visit https://groups.google.com/groups/opt_out.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Mitch,
I am also interested in experimenting with a JSON publisher. It appears
that the github link (github.com/eschluntz/odk_receiver) in the Simple JSON
publisher section of the wiki page is not longer working. Is this or a
similar example available elsewhere on GitHub?
Steve
>> Hi all,
>> suggestions.
>> Thanks,
>> Alan
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
I don't know of one. When I need to, I just set up a port listener and spew
the transmission into a console window for testing purposes.
On Tue, Jan 28, 2014 at 10:41 AM, Steven Hansen wrote:
Mitch,
JSON publisher section of the wiki page is not longer working. Is this or a
Steve
the data directly from ODK Aggregate. See http://code.google.com/p/
suggestions.
I guess I have a related, more basic question.
In ODK Aggregate, I am selecting Publish, and choosing Z-ALPHA JSON Server
and Stream new Submission Data ONLY
I suppose I need more detailed instructions on setting up the URL to
publish to and the Authorization token. I don't have experience with JSON
data, so perhaps this is more of a question about the basics of JSON data
rather than ODK.
Thanks again.
On Tue, Jan 28, 2014 at 10:58 AM, Mitch Sundt wrote:
Perhaps someone in the community can answer this?
spew the transmission into a console window for testing purposes.
Mitch,
Steve
from Aggregate to Google Fusion Tables, and then accessing the data through
suggestions.
You need to have a server that listens for JSON formatted submissions
at the URL you enter. And to ensure that you only get posts that you
want, you can add some authorization token (basically a password that
you check for your server).
If you want a quick and dirty server to test with, attached is the
source for a JSON server I hacked together. It listens for posts on
port 12345 and prints the result out to the command line.
> I suppose I need more detailed instructions on setting up the URL to publish
> to and the Authorization token. I don't have experience with JSON data, so
> perhaps this is more of a question about the basics of JSON data rather than
> ODK.
> Thanks again.
>>> Mitch,
>>> Thanks,
>>> Steve
>>>> access the data directly from ODK Aggregate. See
>>>>> Hi all,
>>>>> documentation is confusing and I'm not sure if it provides the functionality
>>>>> I'm looking for - advice would be appreciated here. Also, I've seen ODK
>>>>> Briefcase, but as this is a standalone jar that still needs to be triggered
>>>>> suggestions.
>>>>> Thanks,
>>>>> Alan
>>>>> Groups "ODK Developers" group.
>>>>> an email to opendatakit-developers+unsubscribe@googlegroups.com.
>>>> Mitch Sundt
>>>> Software Engineer
>>>> mitche...@gmail.com
>> Mitch Sundt
>> Software Engineer
>> mitchellsundt@gmail.com
>> You received this message because you are subscribed to a topic in the
>> Google Groups "ODK Developers" group.
>> To unsubscribe from this topic, visit
>> https://groups.google.com/d/topic/opendatakit-developers/54eHFTwshG8/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to
And note that there are some bugs with the serializer around an extra comma
and strings containing quotes or commas not being properly escaped. These
will be fixed in the ODK Aggregate 1.4.1 release (soon).
On Tue, Jan 28, 2014 at 3:09 PM, Yaw Anokwa wrote:
Steven,
Server
publish
so
than
ODK.
Mitch,
Simple JSON
Steve
needs to be
Aggregate.
to get
data can
through
read that
in that
functionality
ODK
triggered
suggestions.
