Can not open kayzen.el.r.appspot.com
app engine .. odk aggregate .. desktop computer .. windows7 21 bit
i don't know
i don't know
Hi @megabary
The message says:
Your application may have exceeded its per-minute or daily usage quotas
That means you have to wait because you probably exceeded your limits. If you have run out of quota, you can either enable billing or wait 24 hours for the quotas to reset.
Hi Grzesiek2010 .. Thank you
I am Mohamed Arafat .. Egyptian .. IT Consultant at Saudia Arabia Company
i open it next day but still the same problem
Ok so please follow the rest of the instruction:
Please visit Google Cloud Platform - App Engine Dashboard and select your application id from the top-right drop-down. The Billing Status section for your application id is displayed beneath the Summary and Instances sections.
Verify that you have not exceeded your free quota or daily spending limit (if you have set up billing) and that you have also not exceeded your per-minute usage limits.
If your application's usage limits have not been exceeded, then go to Google Cloud Platform - Overview Dashboard and confirm that there are no Google infrastructure issues (these will appear in the Google Cloud status box in the top-right of this page.
If neither of those indicate any problems, then your application's Logs may identify an issue. See ODK Aggregate Troubleshooting for what to look for.
