Still having some issues with my upgrade to 1.1.3 Aggregate. Finally with
some help from Mitch got the Google API Credentials working with a standard
GMail account. Now records are being collected and sent to Aggregate fine
but they are not being pushed or published to Google Spreadsheets and
Fusion Tables. If I delete the published connections and recreate them all
the records that are current on the server get pushed over but no new
records that get collect after that get published. I have tried it with
Stream New Submission Data Only and BOTH upload existing and New
Submissions and no luck. Any ideas? I had this problem once before and
never really figured out why it stop and started working again. The way we
are using the system this is a critical piece of the puzzle.
Any ideas...and thanks again for all the help
Andy
Seems to be working now. There is a 30 minute delay from when it gets on
the server to when it is posted to Google fusion tables or spreadsheets.
Is this normal? I do not remember this taking that long?
Andy
On Sunday, April 21, 2013 8:24:44 AM UTC-5, Andrew Faust wrote:
> 1.3.1 sorry typo
>> with some help from Mitch got the Google API Credentials working with a
>> standard GMail account. Now records are being collected and sent to
>> Aggregate fine but they are not being pushed or published to Google
>> Spreadsheets and Fusion Tables. If I delete the published connections and
>> recreate them all the records that are current on the server get pushed
>> over but no new records that get collect after that get published. I have
>> tried it with Stream New Submission Data Only and BOTH upload existing and
>> New Submissions and no luck. Any ideas? I had this problem once before
>> and never really figured out why it stop and started working again. The way
>> we are using the system this is a critical piece of the puzzle.
>> Andy
There seems something going on with the publishing. Sometimes works and then other times nothing gets pushed over.
I will keep doing some testing and let everyone know if I figure anything out.
Andy
Still not pushing records from server to Google. Any thoughts?
What platform are you running on? Have you looked at the log for error
messages? What do the error messages say?
I am facing problems when publishing to google spreadsheet , only two rows
are exported with the same records , any hints? Is this a common problem?,
i didnt have this problems previously. I am using aggregate 1.3 via linux ,
best
Check the catalina log for errors.
best
Groups "ODK Community" group.
Invite me to be a developer
http://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
I can see what I can do.
What sequence of actions were you doing prior to this? (be as specific as
possible; the clearer you can explain the sequence, the more likely I will
be able to figure out how it broke and prevent it from happening in the
future).
And what form(s) did you want removed from your ODK Aggregate server? (I
will likely need to do some manual deletion of data)
On Thu, Apr 25, 2013 at 8:34 AM, wrote:
Hi there I was facing the problems related in my previous email above,
then I tried to delete the published data in the Form management tab, then
when deleting the different published data both spreadsheets and fusion
tables a problem occurred and I keep on getting this screen prompt ( see
attached) , I am currently implementing a field survey and I am afraid of
not been able of publishing.
I tried changing the google API credentials but it didnt solve the problem
anyone can help me to solve this issue?
Uuurgggh. OK. There appear to be 3 different users with 3 different things
going on all chiming on on this one e-mail thread. Please stop.
Andrew
I am having no trouble publishing your "STORM" data to Google Spreadsheets
or Fusion Tables. It publishes quickly and is immediately visible.
Are you publishing to a gmail.com account? Note that this issue
http://code.google.com/p/opendatakit/issues/detail?id=776&start=100 ,
reported on this group several times already, makes it impossible to
publish to a non- @gmail.com account.
If that is not the cause of your problem, what does your catalina.log
contain?
Everyone Else
Please create a completely new e-mail with a different subject line, and
re-describe your problems.
On Thu, Apr 25, 2013 at 6:35 PM, Andrew Faust afaust@ncwrpc.org wrote:
Windows.
Unsubscribe: opendatakit...@**googlegroups.com
an email to opendatakit...@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
It should be working now.
Code fix for this is pushed and will be in the next ODK Aggregate release
(we were deleting the publisher without first gaining a task lock that
would prevent the publisher from running, so the delete was happening at
the same time as the publish, resulting in a race condition)
On Thu, Apr 25, 2013 at 11:15 AM, wrote:
Hello Mitch I will try to explain it in a better way:
In the aggregate server there is only one form named KAP survey, the
field team is gathering data and sending submissions rigth now , so I dont
contemplate delete the form as there is risk of loosing all the data
gathered up to now. As I was facing some publishing problems ( repeated
records & incomplete documents lacking responses in the google fusion and
spreadsheed published documents ) I decided to delete both the published
documents in google drive and the published data under the form management
tab in aggregate with the idea of starting again publishing new documents
and wait longer in order to see if the published documents in google
drive are ok
The sequence of actions I was doing prior to this happen is
1.In aggregate clicked on Form management tab
2.clicked on Published data tab
3.clicked on x for delete a google spreadsheed published doc
(when I did this it didnt worked I mean that when I clicked teh document
was there , I clicked the remaining docs)
4.I went to drive and deleted the same docs
5.When back into aggregate I got this error message I sent in the previous
email
I am able to export the records to .csv but not fusion tables nor google
spreadsheet publishing works
Its important for me been able to publish in google spreadsheet format
because my cuestionary has lots of repeat groups and i need to easily pull
out that responses from the corresponding tabs created in google
spreadsheet format & fusion table format, in .csv format each group of
repiting answers is in a "link" like
https://odkacf.appspot.com/view/formMultipleValue?formId=KAP_survey[%40version%3Dnull+and+%40uiVersion%3Dnull]%2Fkap_acf_ph_form_final[%40key%3Duuid%3A1ae3764a-56c6-4d5b-943c-cf85f7932769]%2Fwater%3Arepeat_water_source_clean_8
and is a nightmare to pull the answers one by one
I had invited you as a developer , I hope you can help me to solve this
issue
Thanks!!
Sorry for all the confusion. Yes the first publish works. But after new
data comes in it never get pushed over to Google Spreadsheets or Fusion
Tables. Yes I am using a gmail account.
Let me get the log and I will add it to a post.
> things going on all chiming on on this one e-mail thread. Please stop.
> Andrew
> contain?
> Everyone Else
> Mitch
> On Thu, Apr 25, 2013 at 6:35 PM, Andrew Faust <afa...@ncwrpc.org wrote:
>> Windows.
>>>> Post: opend...@googlegroups.com
>>>> You received this message because you are subscribed to the Google
>>>> To unsubscribe from this group and stop receiving emails from it, send
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Hi Mitch thanks for the details, its great to try this avoid happening , I
am logging into aggregate and it keeps refreshing every 3 seconds and I am
unable of looking at the recorded data and manage aggregate , any hint?
2013/4/25 Mitch Sundt
drive are ok
previous email
issue
Thanks!!
https://groups.google.com/d/topic/opendatakit/vVg5TCtHxGQ/unsubscribe?hl=en
I need more of the log history (send it to me directly, not to opendatakit@).
Are you running under Tomcat 6 or under something else?
What happens if you check the 'Disable faster background actions (exports,
publishing, form deletion) (slows quota usage on Google AppEngine)'
checkbox on the Site Admin / Preferences page.
Does the publisher start to work?
Did you do any special configuration for your server, or is it just a
vanilla Tomcat 6 with the installer-generated war file?
On Fri, Apr 26, 2013 at 11:45 AM, Andrew Faust wrote:
Here is another log attached
On Friday, April 26, 2013 1:43:35 PM UTC-5, Andrew Faust wrote:
See log file attached
new data comes in it never get pushed over to Google Spreadsheets or Fusion
Andrew
Spreadsheets or Fusion Tables. It publishes quickly and is immediately
visible.
http://code.google.com/p/**opendatakit/issues/detail?id=**776&start=100http://code.google.com/p/opendatakit/issues/detail?id=776&start=100, reported on this group several times already, makes it impossible to
contain?
Everyone Else
and re-describe your problems.
On Thu, Apr 25, 2013 at 6:35 PM, Andrew Faust afa...@ncwrpc.orgwrote:
Windows.
error messages? What do the error messages say?
Unsubscribe: opendatakit...@**googlegroups.**com
Options: http://groups.google.com/**group**/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en
send an email to opendatakit...@**googlegroups.**com.
For more options, visit https://groups.google.com/**grou**ps/opt_outhttps://groups.google.com/groups/opt_out
Unsubscribe: opendatakit...@googlegroups.**com
an email to opendatakit...@googlegroups.**com.
mitche...@gmail.com
I have seen this before. Try to restart server.
Also Mitch what is the fix for the publishing? It still does not work for
me.
Andy
> I am logging into aggregate and it keeps refreshing every 3 seconds and I
> am unable of looking at the recorded data and manage aggregate , any hint?
> 2013/4/25 Mitch Sundt <mitche...@gmail.com >
>> Mitch
>>> drive are ok
>>> previous email
>>> https://odkacf.appspot.com/view/formMultipleValue?formId=KAP_survey%5B%40version%3Dnull+and+%40uiVersion%3Dnull%5D%2Fkap_acf_ph_form_final%5B%40key%3Duuid%3A1ae3764a-56c6-4d5b-943c-cf85f7932769%5D%2Fwater%3Arepeat_water_source_clean_8
>>> issue
>>> Thanks!!
>>> an email to opendatakit...@googlegroups.com .
>> Mitch Sundt
>> Software Engineer
>> mitche...@gmail.com
An old server running Windows Server 2003 Service Pack 2, Tomcat 6.0.35,
MySQL 5.5. I did rename the war file to ROOT.
I did check "Disable Dater Background actions..." and no change.
Andy
> opendatakit@).
> (exports, publishing, form deletion) (slows quota usage on Google
> AppEngine)'
> Mitch
>>>>> Andrew
>>>>> visible.
>>>>> contain?
>>>>> Everyone Else
>>>>> Mitch
>>>>> On Thu, Apr 25, 2013 at 6:35 PM, Andrew Faust wrote:
>>>>>> Windows.
>>>>>>>> ps/opt_out .
>>>>>> send an email to opendatakit...@googlegroups.**com.
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
