PULL Problem no from being recognized
I do have a problem in pulling some instances as ODK briefcase can not recognize the form in the forms folder.
Since no form is recognized by ODK briefcase 1.4.4 I am not able to pull my data.
I have already tried to regenerate the form from xls to xlm but it does not work.
What could be the reason behind and how can i solve this issue? Many thanks
Gabriele
First, upgrade to ODK Briefcase 1.4.5 https://opendatakit.org/downloads/
Does this fix the problem?
With each release, we add new features and functions to the javarosa XForms
language. If the form on the server uses any of those new features, an
older ODK Briefcase will not be able to download and open the form.
If it doesn't fix the issue, I ( mitchellsundt@gmail.com ) would need
access to your server.
https://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
my data.
not work.
Gabriele
Ah, OK.
It appears that ona.io modifies the form definition or returns something
that is not recognized by ODK Briefcase. This would be something for the
Ona support people to respond to.
Ona and ODK Aggregate both communicate through standardized interfaces (
https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaAPI ) with ODK Collect.
ODK Briefcase, however, uses APIs that are defined by the ODK team (
https://code.google.com/p/opendatakit/wiki/BriefcaseAggregateAPI ) and
these may or may not be fully implemented on Ona.
ODK Briefcase should be able to submit data to Ona (because that interface
is the same as used by ODK Collect to submit data), but it may or may not
be able to download data from Ona -- that is dependent upon whether Ona
implements the ODK download APIs.
··· On Tue, Mar 24, 2015 at 10:17 AM, Arcc Drc wrote:
Hi Mitch, many thanks for your help. I tried the last version but it still
does not work.
I was not using a server but ODK offline, however a colleague (Cc) tried
to understand what the problem was so he upload the form on ONA.io and then
from briefcase he tried to pull data from server ona and that is the error
message he got:
Fetching form definition
resolving against briefcase form definitions
Error parsing form definition:
org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: The data
model does not have an id or xmlns attribute. Add an id="your.domain.org:formId"
attribute to the top-level instance data element of your form.
I attach you the form as well as the instances. Many thanks for your kind
help it is much appreciated.
Let me know what else can I do
Best
Gabriele
XForms language. If the form on the server uses any of those new features,
an older ODK Briefcase will not be able to download and open the form.
If it doesn't fix the issue, I ( mitche...@gmail.com ) would need access
to your server. https://code.google.com/p/opendatakit/wiki/
my data.
not work.
thanks
Gabriele
Groups "ODK Community" group.
mitche...@gmail.com
Well actually the form was developed with ODK xiframe. We usually download
the data offline from the different Androids and then consolidate them here
in the office with ODK briefcase. Since it was not working this time with
the form attached, my colleague Patrick did try tu use ona.io.
Mitch would you be so kind to have a look to the form attached and find out
whether you can understand we ODK briefcase does not recognize it to pull
data?
Many thanks for your time
Gabriele
ARCC_PDM_cash_v2e5.xls (128 KB)
ARCC_PDM_cash_v2e5.xml (201 KB)
··· On Tuesday, March 24, 2015 at 7:54:29 PM UTC+2, Mitch Sundt wrote: > > Ah, OK. > > It appears that ona.io modifies the form definition or returns something > that is not recognized by ODK Briefcase. This would be something for the > Ona support people to respond to. > > Ona and ODK Aggregate both communicate through standardized interfaces ( > https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaAPI ) with ODK > Collect. > > ODK Briefcase, however, uses APIs that are defined by the ODK team ( > https://code.google.com/p/opendatakit/wiki/BriefcaseAggregateAPI ) and > these may or may not be fully implemented on Ona. > > ODK Briefcase should be able to submit data to Ona (because that interface > is the same as used by ODK Collect to submit data), but it may or may not > be able to download data from Ona -- that is dependent upon whether Ona > implements the ODK download APIs. > > > > On Tue, Mar 24, 2015 at 10:17 AM, Arcc Drc <arccun...@gmail.com > wrote: > >> >> Hi Mitch, many thanks for your help. I tried the last version but it >> still does not work. >> >> I was not using a server but ODK offline, however a colleague (Cc) tried >> to understand what the problem was so he upload the form on ONA.io and then >> from briefcase he tried to pull data from server ona and that is the error >> message he got: >> >> Fetching form definition >> resolving against briefcase form definitions >> Error parsing form definition: >> org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: The data >> model does not have an id or xmlns attribute. Add an >> id="your.domain.org:formId" attribute to the top-level instance data >> element of your form. >> >> I attach you the form as well as the instances. Many thanks for your kind >> help it is much appreciated. >> Let me know what else can I do >> >> Best >> Gabriele >> >> >> >> >> On Tuesday, March 24, 2015 at 4:59:33 PM UTC+2, Mitch Sundt wrote: >>> >>> First, upgrade to ODK Briefcase 1.4.5 https://opendatakit.org/downloads/ >>> >>> Does this fix the problem? >>> >>> With each release, we add new features and functions to the javarosa >>> XForms language. If the form on the server uses any of those new features, >>> an older ODK Briefcase will not be able to download and open the form. >>> >>> If it doesn't fix the issue, I ( mitche...@gmail.com ) would need >>> access to your server. https://code.google.com/p/opendatakit/wiki/ >>> AppEngineTroubleshooting >>> >>> >>> On Mon, Mar 23, 2015 at 5:47 AM, wrote: >>> >>>> I do have a problem in pulling some instances as ODK briefcase can not >>>> recognize the form in the forms folder. >>>> >>>> Since no form is recognized by ODK briefcase 1.4.4 I am not able to >>>> pull my data. >>>> >>>> I have already tried to regenerate the form from xls to xlm but it does >>>> not work. >>>> >>>> What could be the reason behind and how can i solve this issue? Many >>>> thanks >>>> Gabriele >>>> >>>> -- >>>> -- >>>> Post: opend...@googlegroups.com >>>> Unsubscribe: opendatakit...@googlegroups.com >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>> >>>> --- >>>> You received this message because you are subscribed to the Google >>>> Groups "ODK Community" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to opendatakit...@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> >>> >>> -- >>> Mitch Sundt >>> Software Engineer >>> University of Washington >>> mitche...@gmail.com >>> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >
For the ODK tools, the version number must be an integer.
In these forms, you are using "2.5"
Also, the integer is compared using string comparison, so the numbers are
ranked in alphabetical order, so "10" < "2".
Therefore, we recommend using a version number format of:
yyyymmddvv
The number can be no longer than 10 digits, with a leading 2.
So, e.g.,
2015032401
would be the 1st revision to the form that you developed on March 24, 2015.
out whether you can understand we ODK briefcase does not recognize it to
pull data?
Gabriele
Ah, OK.
Collect.
interface is the same as used by ODK Collect to submit data), but it may or
may not be able to download data from Ona -- that is dependent upon whether
Ona implements the ODK download APIs.
message he got:
Error parsing form definition: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData:
The data model does not have an id or xmlns attribute. Add an
kind help it is much appreciated.
Best
Gabriele
ads/
pull my data.
does not work.
thanks
Gabriele
mitche...@gmail.com
mitche...@gmail.com
MANY MANY THANKS MITCH, YOU Helped us a LOT!
I managed to get the form recognized, unfortunately the offline export still says failed… mayde due to the clash between version in the forms and the version in the instances. However I did extract the data thanks to the ona.io server.
LESSON learnt
HAVE A GREAT DAY
Gabriele
··· From: Mitch Sundt [mailto:mitchellsundt@gmail.com] Sent: Wednesday, March 25, 2015 4:39 PM To: ODK Community Cc: patrick.konan.n@gmail.com; Gabriele Erba; "mitche..."@gmail.com Subject: Re: [ODK Community] PULL Problem no from being recognized
Also, the integer is compared using string comparison, so the numbers are ranked in alphabetical order, so "10" < "2".
yyyymmddvv
So, e.g.,
2015032401
On Wed, Mar 25, 2015 at 1:37 AM, Arcc Drc <arccunicefdrc@gmail.commailto:arccunicefdrc@gmail.com> wrote:
Well actually the form was developed with ODK xiframe. We usually download the data offline from the different Androids and then consolidate them here in the office with ODK briefcase. Since it was not working this time with the form attached, my colleague Patrick did try tu use ona.iohttp://ona.io.
Mitch would you be so kind to have a look to the form attached and find out whether you can understand we ODK briefcase does not recognize it to pull data?
Gabriele
Ah, OK.
It appears that ona.iohttp://ona.io modifies the form definition or returns something that is not recognized by ODK Briefcase. This would be something for the Ona support people to respond to.
Ona and ODK Aggregate both communicate through standardized interfaces ( https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaAPI ) with ODK Collect.
ODK Briefcase, however, uses APIs that are defined by the ODK team ( https://code.google.com/p/opendatakit/wiki/BriefcaseAggregateAPI ) and these may or may not be fully implemented on Ona.
ODK Briefcase should be able to submit data to Ona (because that interface is the same as used by ODK Collect to submit data), but it may or may not be able to download data from Ona -- that is dependent upon whether Ona implements the ODK download APIs.
On Tue, Mar 24, 2015 at 10:17 AM, Arcc Drc <arccun...@gmail.commailto:arccun...@gmail.com> wrote:
Hi Mitch, many thanks for your help. I tried the last version but it still does not work.
I was not using a server but ODK offline, however a colleague (Cc) tried to understand what the problem was so he upload the form on ONA.io and then from briefcase he tried to pull data from server ona and that is the error message he got:
Error parsing form definition: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: The data model does not have an id or xmlns attribute. Add an id="your.domain.org:formId" attribute to the top-level instance data element of your form.
I attach you the form as well as the instances. Many thanks for your kind help it is much appreciated.
Best
Gabriele
With each release, we add new features and functions to the javarosa XForms language. If the form on the server uses any of those new features, an older ODK Briefcase will not be able to download and open the form.
If it doesn't fix the issue, I ( mitche...@gmail.commailto:mitche...@gmail.com ) would need access to your server. https://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
On Mon, Mar 23, 2015 at 5:47 AM, <arccun...@gmail.commailto:arccun...@gmail.com> wrote:
Gabriele
Post: opend...@googlegroups.commailto:opend...@googlegroups.com
Unsubscribe: opendatakit...@googlegroups.commailto:opendatakit...@googlegroups.com
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.commailto:opendatakit...@googlegroups.com.
Post: opendatakit@googlegroups.commailto:opendatakit@googlegroups.com
Unsubscribe: opendatakit+unsubscribe@googlegroups.commailto:opendatakit%2Bunsubscribe@googlegroups.com
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.commailto:opendatakit+unsubscribe@googlegroups.com.
mitchellsundt@gmail.commailto:mitchellsundt@gmail.com
