pulldata function is not working.
The app is odk collect v1.28.3
I have tried everything possible and mentioned in the forum for more than 10 days
but there should be a problem
the sample form is attached and the csv file.FHK_Dist_Reg_SHE_Rehab_sample.xlsx (11.5 KB) items.csv (56 Bytes)
Hi Moteb, I hope that you are well.
In the csv file you attached the id_key field matches the "label" column in the choices tab of your form. It needs to match the "name" column. Everything else in your form looks good and the pull data function seems to have no errors.
I hope this helps. If it still doesnt work for you let me know and I can modify your example. The easiest way to fix it is probably just to make the names and the labels for the "id" choices the same.
Noel
Thanks a lot, Noel,
The problem solved and you caught it exactly.
Yes I am doing well.
How about you?
Thanks for confirming all works now. I am doing well and happy to make a very small contribution to one of your projects.
