Kobotoolbox where I aggregate data is downloading incomplete data (some columns have missing information; information exists when individual forms are reviewed). This problem has persisted for months, so I am considering options such as Aggregate.
I used ODK Briefcase to pull data after backing up all ODK folders from devices. However exported output are not consistent with number of interviews I expect to have.
Therefore I would like to know if its possible to push ODK instances to Aggregate (I am yet to create an aggregate account) so that I can later download the datasets from Aggregate
Written to Kobotoolbox support. No response.
I will set up an aggregate account and try to migrate instances to aggregate so i can download
