This is possible but requires some creativity.
First, you ask the question.
select_one tile_options, q1, Which type of ceramic tiles do you use?
Then, ask for the text box for other.
text, q1_other, Please describe the other ceramic tile.
This text box should only be relevant when you select other, so add
this in the relevant column.
selected(${q1}, 'other')
Then you'll need to use a calculate question to build a label from
both the selects and the text box.
calculate, q1_label
Put this in the calculation column.
if(selected(${q1}, 'other'),${q1_other}, jr:choice-name(${q1},'${q1}'))
What this calculation says is if q1 is other, then store whatever you
typed in other. Else, store the label, not the name, of whatever
choice you made in q1.
Now you can use ${q1_label} wherever.
note, q2, Your q1 answer's label was ${q1_label}
That's it! I have attached an XLS and XML example for you to play with.
other.xml (1.67 KB)
other.xlsx (10.5 KB)
On Thu, Aug 18, 2016 at 7:05 PM, resmarklimited@gmail.com wrote:
Hello House,
Thank you all for this platform, its really wonderful
A quick one!
I just finished designing my form and while testing it on Enketo before I
convert to Xform, I realized that after writing the response to the 'other
option' question, its left hanging and there is no way the interviewer can
connect or bring it up in the next question that involves that answer .
For example:
q1. Which type of ceramic tiles do you use.
a. Gray Pale
b. Glazed
c. Other
After selecting 'c' and writing Mosaic as my answer to the 'other', there is
no way to tie mosaic to my next question since the 'other' still appears as
'other' instead of Mosaic
My question is, is it possible to change 'other' to Mosaic in the next
question? What if I have an option of two 'others', how do I tie each
response to the next question with the individual 'other' chosen in the
current question. I don't know if this makes sense I just hope someone can
help me out on how to go about it.
