I am using the random() function to sample a respondent from a household
roster in the tablet. This is possible because the random() number doesn't
change while navigating within the form. However, I realized now that the
random() number is recalculated when the form is opened for editing after
saving it. While I can understand this behavior as long as the form is not
yet finalized, I was quite surprised that the random() number is also
recalculated if the form is edited after it was already finalized.
Is this behavior intended?
And is there anything I can do to avoid the recalculation of the random
number after the form was finalized?
Fortunately, the 'new' random number is not saved if one selects 'Ignore
Changes' but it is still very confusing since - in my case - a different
household member is shown if the form is opened after finalization
Another question along these lines: Is there an option to prohibit any
changes in 'finalized' forms? While I don't have a tablet in front of me
now, I think I only saw an option to make the button 'Edit Saved Forms'
disappear - but I sometimes need enumerators to edit/continue saved (but
not yet finalized) forms.
Thank you very much for your help, best,
Utz
Utz J Pape
Economist (Consultant)
World Bank, South Sudan
+211 9541 58978
Hi Utz,
I have a suggestion for a work around you could use. You can generate your
own pseudo-random numbers using the form's start time. Since the start time
should never change you'll always get the save value every time you open
the form. Here's an example of how to generate a pseudo-random number
greater than or equal to 0 and less than X:
int((${start_time} - date(0)) * 100000) mod X
Multiplying by 100000 makes it so you get a new random number every second.
You wouldn't want all the forms started on the same day/hour/minute to have
the the same random value.
Regards,
-Nathan
On Wednesday, May 15, 2013 12:29:09 AM UTC-7, Utz Pape wrote:
> Hi,
> Utz
> Utz J Pape
> +211 9541 58978
Thank you so much - I like the idea. Unfortunately, I don't really get it working properly because for some reason the variable with the start time only returns the date.
So, I created a test form in Excel:
type
name
start start_time
calculate number(${start_time})
However, this always returns 15841 (at least today) - and doesn't change. Now, I tried many things like multiplying by 1000 to get hours, minutes and seconds - but it seems that the ${start_time} only contains the date without the time. I also tried int() instead of number(); and even if I look at it as string(${start_time}) I get '2013-05-16'. Even if I say format-date(${start_time}, '%Y/%n/%e %H:%M'), I receive '2013/5/16 00:00'.
I also checked the form after filling it out - in the resulting Excel file, the field start contains '2013-05-16T12:04:00.561+03'.
Any idea what I do wrong?
Thank you!
Utz
Utz J Pape
+211 9541 58978
Date: 05/15/2013 08:43PM
Cc: upape@worldbank.org
Subject: Re: random number changes after finalization
Hi Utz,
I have a suggestion for a work around you could use. You can generate your own pseudo-random numbers using the form's start time. Since the start time should never change you'll always get the save value every time you open the form. Here's an example of how to generate a pseudo-random number greater than or equal to 0 and less than X:
Multiplying by 100000 makes it so you get a new random number every second. You wouldn't want all the forms started on the same day/hour/minute to have the the same random value.
Regards,
-Nathan
I am using the random() function to sample a respondent from a household roster in the tablet. This is possible because the random() number doesn't change while navigating within the form. However, I realized now that the random() number is recalculated when the form is opened for editing after saving it. While I can understand this behavior as long as the form is not yet finalized, I was quite surprised that the random() number is also recalculated if the form is edited after it was already finalized.
And is there anything I can do to avoid the recalculation of the random number after the form was finalized?
Fortunately, the 'new' random number is not saved if one selects 'Ignore Changes' but it is still very confusing since - in my case - a different household member is shown if the form is opened after finalization
Another question along these lines: Is there an option to prohibit any changes in 'finalized' forms? While I don't have a tablet in front of me now, I think I only saw an option to make the button 'Edit Saved Forms' disappear - but I sometimes need enumerators to edit/continue saved (but not yet finalized) forms.
I'm really sorry Utz, I only tested the timestamp idea in enketo. It looks
like there is a bug in Collect/JavaRosa that makes the time portion of
timestamps inaccessible: https://code.google.com/p/opendatakit/issues/detail?id=808&q=datetime
Hopefully that gets fixed soon.
Regards,
-Nathan
On Thursday, May 16, 2013 3:56:38 AM UTC-7, up...@worldbank.org wrote:
> Dear Nathan and others,
> type name
> start start_time
> Thank you!
> Utz
> Utz J Pape
> +211 9541 58978
> -----Nathan <nab...@gmail.com > wrote: -----
> To: opend...@googlegroups.com
> From: Nathan <nab...@gmail.com >
> Cc: up...@worldbank.org
> Hi Utz,
> Regards,
> -Nathan
>> Hi,
>> Utz
>> Utz J Pape
>> +211 9541 58978
There is also a fix for the random()/uuid() bug pending. Mitch will
know better, but I bet that fix it'll be in the next release of
Collect.
> Regards,
> -Nathan
>> type name
>> start start_time
>> Thank you!
>> Utz
>> Utz J Pape
>> +211 9541 58978
>> -----Nathan wrote: -----
>> From: Nathan
>> Hi Utz,
>> Regards,
>> -Nathan
>>> Hi,
>>> Utz
>>> Utz J Pape
>>> +211 9541 58978
> "ODK Community" group.
> For more options, visit https://groups.google.com/groups/opt_out.
