Hi folks,
I don't have sucess using sintaxes with range.
i need something like the Xform attached. this i was doing with ODK build
but not right in ODK collect. in purcforms i can't do it.
thanks for yours attention!!!
Untitled Form.xml (1.4 KB)
Hi folks,
you can't use the comma syntax for your number. instead of 31,4 it
should be 31.4.
i've fixed the form and put it at http://dpaste.com/397522/
hi renan,
the xpath syntax requires decimals to be expressed as '.', not using a comma
(','). try changing that and testing again. your constraints look otherwise
fine to me.
example: constraint=". > 4.0"
Hi folks,
but not right in ODK collect. in purcforms i can't do it.thanks for yours attention!!!
Renan A. Kamimura--
Yaw, it´s perfect!!!
thanks a lot !!!!
congratulations on his team's work and of course the availability and
attention!
renan
should be 31.4.i've fixed the form and put it at http://dpaste.com/397522/
2011/2/8 Renan Kamimura renankami@gmail.com:
Hi folks,
Renan A. Kamimura--
Renan A. Kamimura
