Raspberry Installation
i amtrying to install ODK server on a raspberry pi 2 with raspbian.
When trying to execute sudo ./ODK\ Aggregate\ v1.4.10\ linux-installer.run
I get
./ODK Aggregate v1.4.10 linux-installer.run: Syntax error: "(" unexpected
Anyone coould install on Raspberry?
May be is better to install Ubunto than Raspbian?
THank you
The installer does nothing other than configure a WAR file.
Run it on your own computer, then copy the generated WAR to the Raspberry.
I get
THank you
Mitch,
The problem is probably that the shell script doesn't begin with a
shebang line and so it's being run with /bin/sh.
··· -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
I get
THank you
