I am working on ODK Survey.
I have an excel file that is ODK Collect compatible and I am converting it
to ODK Survey format
In "Calculation" column I have following formula:
if( count-selected(${crop_products_mc_wf_f1}) >= 1,
selected-at(${crop_products_mc_wf_f1},0),'-')
I removed if condition under "clause" column and kept the assign part in
calculation. Still I get following error
ReferenceError: operation is not defined
Can please anyone help to transform this formula or achieve equivalent in
ODK Survey?
I have attached excel file for reference.
Thanks & Regards
Pradnya
FDSurvey1.xlsx (26 KB)
In Survey, we have eliminated the ${} syntax.
Replace any ${fieldname} with data('fieldname')
Since Survey uses Javascript directly for its calculations, we needed to
have a function ( data(arg) ) that took an argument and returned the field
value. ${} would have required transforming the expression text, which we
wanted to eliminate.
w.r.t. calculate expressions, these are wrapped by return statements
internally:
function(...) {
return ( value_from_xlsx_cell );
If you are familiar with javascript, this opens up the possibility of doing
anything you want (e.g., calling your own custom functions).
ODK Survey?
Thanks & Regards
Pradnya
Hi Mitch
Thanks for your reply.
I changed the expression to
selected-at(data('crop_products_mc_wf_f1'),0)
and it is present under "calculation" column. I still get the error. I
assume that "selected-at" function in not present and I will write custom
function to achieve this.
Thanks & Regards
Pradnya
> internally:
> function(...) {
> doing anything you want (e.g., calling your own custom functions).
>> it to ODK Survey format
>> ODK Survey?
>> Thanks & Regards
>> Pradnya
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Sorry for the confusion.
In ODK Survey, multiple-choice fields are represented as *arrays *of values
directly.
We have defined:
selected( data('fieldname'), 'value')
countSelected( data('fieldname') )
For the selected-at( data('fieldname'), n ) functionality, you can directly
use the javascript subscript [n] notation:
(data('fieldname'))[0] -- to get the first selection
(data('fieldname'))[1] -- to get the second selection
etc.
On Wed, Jun 11, 2014 at 12:46 AM, Pradnya wrote:
Hi Mitch
Thanks & Regards
Pradnya
internally:
function(...) {
in ODK Survey?
Thanks & Regards
Pradnya
Groups "ODK Community" group.
mitche...@gmail.com
Hi Mitch
Thanks for your response.
I still get the same error after using javascript subscript [n] notation.
Please find attached excel file that generates this error
> values directly.
> We have defined:
> directly use the javascript subscript [n] notation:
> etc.
> On Wed, Jun 11, 2014 at 12:46 AM, Pradnya <pska...@gmail.com wrote:
>> Hi Mitch
>> Thanks & Regards
>> Pradnya
>>> internally:
>>> function(...) {
>>>> in calculation. Still I get following error
>>>> in ODK Survey?
>>>> Thanks & Regards
>>>> Pradnya
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Ah, OK. There is an error in the construction of the error message in
XLSConverter. The error should read:
Field name 'crop_mc_wf_f1_product1' does not have a defined storage type.
Clause: 'assign' at row 16 on sheet: survey. Declare the type on the model
sheet or in a model.type column.
Attached is an updated XLSXConverter.js file that fixes this error message.
Place in in the application designer's xlsxconverter directory.
XLSXConverter.js (110 KB)
On Tue, Jun 17, 2014 at 5:36 AM, Pradnya wrote:
Hi Mitch
values directly.
We have defined:
etc.
On Wed, Jun 11, 2014 at 12:46 AM, Pradnya pska...@gmail.com wrote:
Hi Mitch
I changed the expression to selected-at(data('crop_
Thanks & Regards
Pradnya
to have a function ( data(arg) ) that took an argument and returned the
field value. ${} would have required transforming the expression text,
which we wanted to eliminate.
internally:
function(...) {
converting it to ODK Survey format
in ODK Survey?
Thanks & Regards
Pradnya
mitche...@gmail.com
mitche...@gmail.com
Thanks for the updated .js file. I have placed it in the appropriate
folder.
I have tried both options: i.e.
- Added model.type column in "survey" sheet [Attachment: FDSurvey1.xlsx ]
- Added sheet "model" and defined "crop_mc_wf_f1_product1" as text
[Attachment:FDSurvey1.xlsx ]
Both of the files give the new error which you have already mentioned below.
FDSurvey1.xlsx (26.2 KB)
FDSurvey2.xlsx (26.7 KB)
> message. Place in in the application designer's xlsxconverter directory.
> On Tue, Jun 17, 2014 at 5:36 AM, Pradnya <pska...@gmail.com > wrote:
>> Hi Mitch
>>> values directly.
>>> We have defined:
>>> etc.
>>>> Hi Mitch
>>>> Thanks & Regards
>>>> Pradnya
>>>>> internally:
>>>>> function(...) {
>>>>>> equivalent in ODK Survey?
>>>>>> Thanks & Regards
>>>>>> Pradnya
>>>>>> send an email to opendatakit...@googlegroups.com.
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Give the attached file a try. I modified your FDSurvey1.xlsx file to
include a row that defines the "crop_mc_wf_f1_product1" as type text. I
also changed the values in the required column of your survey worksheet to
TRUE since putting evaluates to an error. Finally, I noticed that you are
using ${name_field1} in the display.text column. The new syntax is
{{data.}}. For example, if you wanted to display the data of the
prompt tenure_field1, you would use {{data.tenure_field1}}.
Clarice
FDSurvey.xlsx (25.1 KB)
folder.
below.
On Tue, Jun 17, 2014 at 5:36 AM, Pradnya pska...@gmail.com wrote:
Hi Mitch
notation.
values directly.
We have defined:
etc.
Hi Mitch
I changed the expression to selected-at(data('crop_product
s_mc_wf_f1'),0)
I assume that "selected-at" function in not present and I will write custom
Thanks & Regards
Pradnya
internally:
function(...) {
part in calculation. Still I get following error
Thanks & Regards
Pradnya
mitche...@gmail.com
mitche...@gmail.com
mitche...@gmail.com
Thanks Clarice for your help!
It works, I get translated formDef.json file now. In the "Preview" tab I
can see my form. But when I click on it , nothing happens..Nothing changes
on the screen. I have attached the java-script console output.The error is
at line number 92. The error message is hard to understand.
Any help is appreciated
Thanks again
ODK_error.txt (7.02 KB)
> Clarice
>> folder.
>> 1. Added model.type column in "survey" sheet [Attachment: FDSurvey1.xlsx ]
>> 2. Added sheet "model" and defined "crop_mc_wf_f1_product1" as text
>> below.
>>> type. Clause: 'assign' at row 16 on sheet: survey. Declare the type on the
>>> model sheet or in a model.type column.
>>>> Hi Mitch
>>>> notation.
>>>>> values directly.
>>>>> We have defined:
>>>>> etc.
>>>>>> Hi Mitch
>>>>>> s_mc_wf_f1'),0)
>>>>>> Thanks & Regards
>>>>>> Pradnya
>>>>>>> needed to have a function ( data(arg) ) that took an argument and returned
>>>>>>> the field value. ${} would have required transforming the expression text,
>>>>>>> internally:
>>>>>>> function(...) {
>>>>>>> of doing anything you want (e.g., calling your own custom functions).
>>>>>>>> Thanks & Regards
>>>>>>>> Pradnya
>>>>>>> Mitch Sundt
>>>>>>> Software Engineer
>>>>>>> mitche...@gmail.com
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
Here is the excel file, I have updated display.text column and used the new
syntax to display the data of the prompts.
Pradnya
FDSurvey.xlsx (25 KB)
> Clarice
>> folder.
>> below.
>>>> Hi Mitch
>>>> notation.
>>>>> values directly.
>>>>> We have defined:
>>>>> etc.
>>>>>> Hi Mitch
>>>>>> s_mc_wf_f1'),0)
>>>>>> Thanks & Regards
>>>>>> Pradnya
>>>>>>> internally:
>>>>>>> function(...) {
>>>>>>>> Thanks & Regards
>>>>>>>> Pradnya
>>>>>>> Mitch Sundt
>>>>>>> Software Engineer
>>>>>>> mitche...@gmail.com
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
Thank you for taking the time to provide the log. The warning in the
ODK_error.txt files does happen on occasion during normal operation and is
not necessarily indicative of an error condition.
I was able to generate a formDef.json from your latest excel file and
navigate through your form using the Application Designer. A few questions
come to mind.
- Are you using the development tip of the opendatakit.survey-js repo?
- For clarification, have you modified the framework.xlsx file to include
your new form and generated the appropriate formDef.json for these changes?
- In the Preview tab of the Application Designer, are you able to
navigate through the other example forms without any issues?
- Presumably you opened a console and typed 'grunt' in your
opendatakit.survey-js directory in order to open up the Application
Designer. In that console window, do you see any errors?
Clarice
new syntax to display the data of the prompts.
Pradnya
Clarice
folder.
below.
Hi Mitch
notation.
values directly.
We have defined:
etc.
Hi Mitch
s_mc_wf_f1'),0)
error. I assume that "selected-at" function in not present and I will write
custom function to achieve this.
Thanks & Regards
Pradnya
statements internally:
function(...) {
Thanks & Regards
Pradnya
mitche...@gmail.com
mitche...@gmail.com
mitche...@gmail.com
Here are the answers to your questions,
- I am using "ODK ApplicationDesigner v2.0 Alpha-1"
- Yes, I have modified the framework.xlsx file to include my new form and
generated the appropriate formDef.json for these changes. For your
reference I have attached framework.xlsx and it's corresponding
formDef.json file.
- In the Preview tab of the Application Designer, I can navigate through
all the example forms (these forms came as a part of Application Designer)
- Yes, I opened the console window and ran "grunt" command to start the
Application Designer and in that window there are no errors generated when
I click on my form.
Thanks for your help
Pradnya
formDef.json (32.3 KB)
framework.xlsx (13.2 KB)
> come to mind.
> 1. Are you using the development tip of the opendatakit.survey-js repo?
> 2. For clarification, have you modified the framework.xlsx file to
> include your new form and generated the appropriate formDef.json for these
> changes?
> 3. In the Preview tab of the Application Designer, are you able to
> 4. Presumably you opened a console and typed 'grunt' in your
> Clarice
>> Pradnya
>>> Clarice
>>>> folder.
>>>> FDSurvey1.xlsx ]
>>>> below.
>>>>>> Hi Mitch
>>>>>> notation.
>>>>>>> values directly.
>>>>>>> We have defined:
>>>>>>> etc.
>>>>>>>> Hi Mitch
>>>>>>>> s_mc_wf_f1'),0)
>>>>>>>> Thanks & Regards
>>>>>>>> Pradnya
>>>>>>>>> function(...) {
>>>>>>>>>> Thanks & Regards
>>>>>>>>>> Pradnya
>>>>>>>>>> Google Groups "ODK Community" group.
>>>>>>>>> Mitch Sundt
>>>>>>>>> Software Engineer
>>>>>>>>> mitche...@gmail.com
>>>>>>> Mitch Sundt
>>>>>>> Software Engineer
>>>>>>> mitche...@gmail.com
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
Please can anyone help me to resolve the issue mentioned in this thread????
> 1. I am using "ODK ApplicationDesigner v2.0 Alpha-1"
> 2. Yes, I have modified the framework.xlsx file to include my new form and
> formDef.json file.
> 3. In the Preview tab of the Application Designer, I can navigate through
> 4. Yes, I opened the console window and ran "grunt" command to start the
> I click on my form.
> Pradnya
>> come to mind.
>> changes?
>> Clarice
>>> Pradnya
>>>> Clarice
>>>>> folder.
>>>>> FDSurvey1.xlsx ]
>>>>> below.
>>>>>>> Hi Mitch
>>>>>>> notation.
>>>>>>>> values directly.
>>>>>>>> We have defined:
>>>>>>>> etc.
>>>>>>>>> Hi Mitch
>>>>>>>>> Thanks & Regards
>>>>>>>>> Pradnya
>>>>>>>>>> function(...) {
>>>>>>>>>> possibility of doing anything you want (e.g., calling your own custom
>>>>>>>>>> functions).
>>>>>>>>>>> Thanks & Regards
>>>>>>>>>>> Pradnya
>>>>>>>>>>> it, send an email to opendatakit...@googlegroups.com.
>>>>>>>>>> Mitch Sundt
>>>>>>>>>> Software Engineer
>>>>>>>>>> mitche...@gmail.com
>>>>>>>> Mitch Sundt
>>>>>>>> Software Engineer
>>>>>>>> mitche...@gmail.com
>>>>>> Mitch Sundt
>>>>>> Software Engineer
>>>>>> mitche...@gmail.com
Sorry for the slow reply. This somehow got buried in our inboxes. We were
at a conference/meetings last week.
The framework.xlsx file has an error at row 43.
The "FDSurvey" branch_label is not on a separate row, but is on the row
that contains the "exit section" clause.
If you insert a row below row 43, and move the FDSurvey branch_label to
that row, everything should work.
and generated the appropriate formDef.json for these changes. For your
formDef.json file.
I click on my form.
Pradnya
come to mind.
changes?
Clarice
Pradnya
Clarice
folder.
FDSurvey1.xlsx ]
below.
in XLSConverter. The error should read:
Hi Mitch
notation.
values directly.
We have defined:
etc.
Hi Mitch
Thanks & Regards
Pradnya
function(...) {
functions).
assign part in calculation. Still I get following error
Thanks & Regards
Pradnya
mitche...@gmail.com
mitche...@gmail.com
mitche...@gmail.com
I also emailed a response to you directly yesterday with a new
framework.xlsx file and formDef.json file. The email may have gone to your
spam folder.
Clarice
thread????
formDef.json file.
through all the example forms (these forms came as a part of Application
Designer)
I click on my form.
Pradnya
come to mind.
changes?
Clarice
the new syntax to display the data of the prompts.
Pradnya
Clarice
appropriate folder.
FDSurvey1.xlsx ]
mentioned below.
Hi Mitch
notation.
*of values directly.
We have defined:
can directly use the javascript subscript [n] notation:
etc.
Hi Mitch
Thanks & Regards
Pradnya
function(...) {
functions).
Thanks & Regards
Pradnya
mitche...@gmail.com
mitche...@gmail.com
mitche...@gmail.com
Thanks for your response. The issue is sorted and I can see my form.
Clarice Larson also pointed out at the same error and with the corrected
framework.xlsx file the issue is resolved
Many thanks for your help.
Pradnya
> Mitch
>> thread????
>> Thanks
>>> formDef.json file.
>>> Designer)
>>> I click on my form.
>>> Pradnya
>>>> come to mind.
>>>> changes?
>>>> Clarice
>>>>> Pradnya
>>>>>> Clarice
>>>>>>> appropriate folder.
>>>>>>> FDSurvey1.xlsx ]
>>>>>>> mentioned below.
>>>>>>>>> Hi Mitch
>>>>>>>>> notation.
>>>>>>>>>> We have defined:
>>>>>>>>>> etc.
>>>>>>>>>>> Hi Mitch
>>>>>>>>>>> Thanks & Regards
>>>>>>>>>>> Pradnya
>>>>>>>>>>>> function(...) {
>>>>>>>>>>>> functions).
>>>>>>>>>>>>> Thanks & Regards
>>>>>>>>>>>>> Pradnya
>>>>>>>>>>>> Mitch Sundt
>>>>>>>>>>>> Software Engineer
>>>>>>>>>>>> mitche...@gmail.com
>>>>>>>>>> Mitch Sundt
>>>>>>>>>> Software Engineer
>>>>>>>>>> mitche...@gmail.com
>>>>>>>> Mitch Sundt
>>>>>>>> Software Engineer
>>>>>>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Hi Clarice
Many thanks for your email and files.I have replied to your email. Files
provided by you works and now I can see my form
Pradnya
> spam folder.
> Clarice
>> Mitch
>>> thread????
>>> Thanks
>>>> formDef.json file.
>>>> Designer)
>>>> the Application Designer and in that window there are no errors generated
>>>> when I click on my form.
>>>> Pradnya
>>>>> come to mind.
>>>>> repo?
>>>>> changes?
>>>>> Clarice
>>>>>> Pradnya
>>>>>>> to include a row that defines the "crop_mc_wf_f1_product1" as type text. I
>>>>>>> Clarice
>>>>>>>> appropriate folder.
>>>>>>>> FDSurvey1.xlsx ]
>>>>>>>> mentioned below.
>>>>>>>>> storage type. Clause: 'assign' at row 16 on sheet: survey. Declare the type
>>>>>>>>> on the model sheet or in a model.type column.
>>>>>>>>>> Hi Mitch
>>>>>>>>>> notation.
>>>>>>>>>>> We have defined:
>>>>>>>>>>> etc.
>>>>>>>>>>>> Hi Mitch
>>>>>>>>>>>> Thanks & Regards
>>>>>>>>>>>> Pradnya
>>>>>>>>>>>>> function(...) {
>>>>>>>>>>>>> functions).
>>>>>>>>>>>>>> Thanks & Regards
>>>>>>>>>>>>>> Pradnya
>>>>>>>>>>>>> Mitch Sundt
>>>>>>>>>>>>> Software Engineer
>>>>>>>>>>>>> mitche...@gmail.com
>>>>>>>>>>> Mitch Sundt
>>>>>>>>>>> Software Engineer
>>>>>>>>>>> mitche...@gmail.com
>>>>>>>>> Mitch Sundt
>>>>>>>>> Software Engineer
>>>>>>>>> mitche...@gmail.com
>>> an email to opendatakit...@googlegroups.com .
>> Mitch Sundt
>> Software Engineer
>> mitche...@gmail.com
