Hi Chris,
This is very useful in referencing prior IDs. Do you think that in the
repeat, one can also reference prior IDs conditional on some certain
features associating with the IDs. For example, I have IDs of household
members, but I only want to repeat them for all female household members,
or for children under 5 or for adults above 10 of this household. Is there
a index can be added on this one?
Also, I cannot transform the XLS form to XLM. How to insert the "required
addition to XPathFuncExpr.java" you mentioned above to use this
indexed-repeat(repeatedfield, repeatgroup, index) code? I am using the XLS
form converter downloaded from
https://code.google.com/p/opendatakit/downloads/list?can=1&q=&colspec=Filename+Summary+Uploaded+ReleaseDate+Size+DownloadCountand it seemed that this was clearly outdated (uploaded in December 2012).
Thank you.
On Friday, June 7, 2013 6:22:15 AM UTC-4, Christopher Robert wrote:
Just to close the loop on this, in case anybody was following the
discussion...
We released an implementation of this new JavaRosa function in SurveyCTO
today:
indexed-repeat(repeatedfield, repeatgroup, index): References a field or
group that is inside a prior repeat group. The first parameter specifies
the prior field or group in which you are interested; the second specifies
the prior repeat group within which thefield or group of interest is
located; and the third specifies the instance number, within the prior
repeat group, to use. For example, the calculate expression
"indexed-repeat(${name}, ${names}, 1)" will return the first name available
when the "name" field is inside a prior repeat group named "names". From
inside a later repeat group, the calculate expression
"indexed-repeat(${name}, ${names}, position(..))" will pull the xth name
from the prior repeat group, where x is the instance number of the current
repeat group (e.g., if currently in the fourth instance of a repeat group,
it will return the fourth name from the earlier repeat group). See
the multiple-repeat sample form for a simple example. If you need to
reference a field or group within multiple nested repeat groups, you can
supply additional parameters to indicate the instance numbers to use for
each level of nesting. For example, the calculate expression
"indexed-repeat(${name}, ${families}, ${familynumber}, ${names},
${membernumber})" will pull a particular family member's name when family
member names are inside a repeat group that is itself inside a repeat group
of families. See the second multiple-repeat sample form for a much more
complex example that includes three levels of nested repeat groups.
Both sample forms are attached.
We revised the implementation in consultation with Mitch, and he has the
code for this. So, hopefully it -- or a better version, if somebody builds
one -- will become part of the core.
Chris
On Tue, May 28, 2013 at 12:00 PM, Christopher Robert < cro...@surveycto.com> wrote:
Picking back up on this thread... Since there is no current way to
dynamically index prior fields, you can't easily refer to an earlier
repeat-group's fields in later repeat groups. This is a real hindrance.
As a solution, I have added a repeatedfield() function to JavaRosa's
built-in function set. It takes two parameters: a reference to a field
within a repeat group, and an index number to fetch. Together with the
corrected support for position(..) (
https://code.google.com/p/opendatakit/issues/detail?id=822), this allows
you to easily reference a prior repeat group's fields from within a later
repeat group.
Here is the required addition to XPathFuncExpr.java:
} else if (name.equals("repeatedfield") && args.length ==
if (argVals[0] instanceof XPathNodeset) {
XPathNodeset
nodeset=(XPathNodeset)argVals[0];
int index=toInt(argVals[1]).intValue()-1;
if (index >= nodeset.size()) {
return
XPathPathExpr.unpackValue(null);
else {
return (nodeset.getValAt(index));
} else {
throw new
XPathTypeMismatchException("repeatedfield(): first parameter does not refer
to repeated field");
Attached is an example of the kind of form that becomes possible with
this repeatedfield() function, coupled with a functioning position()
function.
Since this is highly-sought-after functionality, would the core team
consider adding these patches to the ODK JavaRosa fork?
Chris
On Tue, May 7, 2013 at 11:41 AM, Christopher Robert < cro...@surveycto.com> wrote:
I have traced the ODK Validate problem, and have filed issue 822 (
https://code.google.com/p/opendatakit/issues/detail?id=822) accordingly.
That is the primary issue standing in the way of people referencing the
current repeat index.
The one-repeat-group-referencing-another problem remains less clear.
Chris
On Mon, May 6, 2013 at 3:23 PM, Christopher Robert cro...@surveycto.com wrote:
Use of the position() function has been mentioned several times, in the
context of related questions. It turns out that position(), called without
any parameters within a repeat group, seems to always return 1. However,
you can call position(..) (or pass the full XPath to the repeat group node
itself, instead of ".."), and the returned value seems to be exactly what
we want: the iteration number of the current repeat group. That's wonderful
news, because it means that we can reference the current iteration number
inside a repeat group.
However, there are two limitations at present:
ODK Validate won't validate these position() calls. The "return
position(((XPathNodeset)argVals[0]).getRefAt(0))" in XPathFuncExpr.java
causes a "java.lang.ArrayIndexOutOfBoundsException: 0 >= 0" exception,
seemingly because the repeat group's nodeset doesn't have any nodes in it
when called in the context of ODK Validate. This obviously has to do with
how ODK Validate loads and walks through a form, and I'm perplexed as to
what's going on.
You can't use the current position to reference a value in a prior
repeat group. For example, you can use
"/formid/repeatgroup1[position()=3]/name" to reference the name field in
the third iteration of repeatgroup1, and you can use
"position(/formid/repeatgroup2)" to reference the current position when
inside repeatgroup2 -- but
"/formid/repeatgroup1[position()=position(/formid/repeatgroup2)]/name" does
not work from inside repeatgroup2. When in the midst of indexing
repeatgroup1, the context doesn't seem suitable for getting your position
in repeatgroup2. If, instead, you stash the current repeatgroup2 position
into a calculated "repeatgroup2/pos" field, you can use that field within
the group -- but unfortunately not as part of indexing repeatgroup1; in the
indexing context, JavaRosa doesn't know which repeatgroup2/pos iteration
you want to reference. So, at the moment, we seem tantalizingly close to
being able to reference a prior repeat group from within a current repeat
group -- but not quite there.
I suspect that there are easy fixes for both of these limitations. Does
somebody more familiar with ODK's JavaRosa/ODKValidate implementations have
any suggestions? Again, I'm happy to make and test the fixes, but it's not
yet obvious to me where the true sources of these problems are.
Chris
On Fri, May 3, 2013 at 10:14 AM, Christopher Robert < cro...@surveycto.com> wrote:
ODK developers,
We are running up against a limitation that has been periodically raised
in this group (but always left unresolved): we would like to reference
prior field values conditional on the current iteration number of a repeat
group. For example:
${agplot${GROUPNUM}} would pull the agplot1 field on iteration 1 of the
repeat group, agplot2 on iteration 2, and so on.
Likewise, we would like one repeat group to be able to reference values
from prior repeat groups. This might look like ${agplot[${GROUPNUM}]} to
pull the GROUPNUMth value of agplot, from within a prior repeat group.
I am not worried about syntax, or even about the XLSForm part of this.
Working out appropriate XPath logic and JaraRosa support seems to be the
major stumbling block. Right now, you can't even reference the current
repeat group's iteration number (i.e., the number that shows at the top of
the entry screen, to indicate which iteration number you are on).
We are happy to do the heavy lifting on this, and to contribute the
solution to ODK/JavaRosa. However, we could very much use guidance from
those of you who have already thought about this.
Any sage advice?
Chris
