I am using index-repeat to refer to previously entered data to create a
choice list and thereafter use that choice list as a select one for
subsequent questions.
Example:
begin repeat: Q1. What crop did you plant in winter? ...
Q2. What crop did you plant in summer? ... Q3. What crop
did you plant in rainy? ...end repeat*
Now this is what I have done:
line1 calculate ......index-repeat (${select_winter},${repeat_name},1)
line2 calculate ...... index-repeat (${select_summer},${repeat_name},2)
line2 calculate ...... index-repeat (${select_rainy},${repeat_name},3)
see attached:
Now instead of returning the three fields, it returns only one field. and
that's the 1st field. Please how can I make it to return the three fields
in every loop?
Also, I used "jr:" Java Rosa to return label instead of name for the
created choice list. How can i save respective choice code instead of
label: Example if maize code was 2 then thats what gets saved instead of
label maize getting saved like the case now:
Hey Collins,
Did you ever get the solution to this. Would be glad if you share...
Whihza
On Friday, 28 February 2014 16:07:15 UTC+1, Collins McAdoyo wrote:
> Hi Team,
> Example:
> *begin repeat: Q1. What crop did you plant in winter? ...*
> * Q2. What crop did you plant in summer? ... Q3. What crop
> see attached:
> in every loop?
> Regards.
> Collins
Yes, I got the way about it. Please what exactly would you like to know? Perhaps you can share with the xls for this section to enable me guide you.
Kind regards.
Collins
-----Original Message-----
Sent: 8/19/2015 3:59 PM
To: "ODK Community"
Subject: [ODK Community] Re: Referencing using Index-repeat
Hey Collins,
Whihza
Hi Team,
I am using index-repeat to refer to previously entered data to create a choice list and thereafter use that choice list as a select one for subsequent questions.
Example:
begin repeat:
Q3. What crop did you plant in rainy?
end repeat
see attached:
Now instead of returning the three fields, it returns only one field. and that's the 1st field. Please how can I make it to return the three fields in every loop?
Also, I used "jr:" Java Rosa to return label instead of name for the created choice list. How can i save respective choice code instead of label: Example if maize code was 2 then thats what gets saved instead of label maize getting saved like the case now:
How do you reference a label in indexed-repeat(${},${},1).. so that you
refer to the label and not the name of the variable?
Stanley.
On Thursday, August 20, 2015 at 5:48:17 PM UTC+3, Collins McAdoyo wrote:
> Dear Whihza,
> Kind regards.
> Collins
> From: Whihza
> To: ODK Community
> Hey Collins,
> Whihza
>> Hi Team,
>> Example:
>> see attached:
>> in every loop?
>> Regards.
>> Collins
> Post: opend...@googlegroups.com
> Unsubscribe: opendatakit...@googlegroups.com
> "ODK Community" group.
> email to opendatakit...@googlegroups.com .
