Regarding default value assignment in XLSform
https://groups.google.com/forum/#!topic/opendatakit/Hoji02D9amY (1)
default problem.docx (107 KB)
This is not how relevant conditions work.
Relevant conditions determine whether or not the value will be saved and
transmitted up to the server. If a field is not relevant, a null (blank)
value will be transmitted to the server, even if you supply a default value
for that field.
https://groups.google.com/forum/#!topic/opendatakit/Hoji02D9amY (1)--
"ODK Developers" group.
email to opendatakit-developers+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
ok. but is there any other way to do the same.
Probably not with ODK Collect.
The ODK 2.0 tools have more flexibility. You can create your own
if-then-else logic, and the constraints and required logic operate
independent of that branching logic.
It would still be difficult, even using ODK Survey, to have the
finalization step jump you to the particular field that needed to have a
value or have been visited by the user.
Some of this depends upon what you want the finalize step to do.
for that field.On Thu, Jun 4, 2015 at 4:54 AM, prafulla Mehar prafull...@gmail.com wrote:
an email to opendatakit-developers+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
mitche...@gmail.com--
