Hi All,
I face some issue with regular expression patter in ODK, as it doesn't
accept any patter to this format "001", I read some posts that it doesn't
count zeros before any other digit although it works well if the patter is
all zeros like regex(.,'^[0][0][0][0]') , however this
"regex(.,'^[0][0]\d{1}$') or regex(.,'^[0]\d{2}$') or regex(.,'^\d{3}$')".
Any thoughts on this would be very appreciated.
-Hanan
To use regex() and handle leading zeros, the field type must be string.
If the field type is integer (or decimal), the string, as entered, is
converted first to an integer or decimal value, and then, if the constraint
specifies a regex(), that internal value is formatted as a string (dropping
all leading zeros), and then that string is evaluated in the regex().
On Tue, Aug 18, 2015 at 2:18 AM, Hanan Aqilan wrote:
Hi All,
-Hanan
Yippe Yip, it worked, thanks for your help Mitch.
I just wanted to share, so others can benefit from this post, this is how I
fixed it followin Mitch's solution:
type name label::english hint::english appearance required constraint
constraint_message::english text child.id Child Id: The child number has
to be 3 digits format ex: 001 numbers yes regex(.,'[0-9][0-9][0-9]') or
regex(.,'[0][0-9][0-9]') or regex(.,'[0][0][0-9]') The child number has
Thanks Mitch.
-Hanan
On Tuesday, August 18, 2015 at 12:18:41 PM UTC+3, Hanan Aqilan wrote:
> Hi All,
> Thanks,
> -Hanan
Thanks Yaw!
The secret key lies in the type of the data which has to be text, otherwise
it will never work even if we used the right pattern.
> Hi All,
> Thanks,
> -Hanan
Hanan,
Pretty sure all you need in the constraint is regex(.,'[0-9][0-9][0-9]')
text child.id Child Id: The child number has to be 3 digits format ex: 001
numbers yes regex(.,'[0-9][0-9][0-9]') or regex(.,'[0][0-9][0-9]') or
regex(.,'[0][0][0-9]') The child number has to be 3 digits format ex: 001
Thanks Mitch.
-Hanan
Hi All,
-Hanan
