${cropname}=30 or ${cropname}=35
You would replace that with
../cropname=30 or ../cropname=35
because this prompt (cropname_other) is within the same group (the clu
repeat group) as cropname.
Furthermore, in your labels, you make reference to ${clu_name} and other
values that are specific to each repeat group.
These will not generate the appropriate text the second time through your
survey. I am not aware of any way to correct this other than hand-editing
the generated XML to replace the full path expression, e.g.,
Name of crop/aquaculture on :
with a relative expression
On Tue, Feb 18, 2014 at 10:48 PM, Collins McAdoyo wrote:
Hi ODKers, I have a form in XLSForm with absolute referencing that seems
not work.
Please, any idea on the use of relative referencing with the
Indexed-repeat in XLSforms would be highly appreciated. Attached is the
xlsform.
Hi am struggling with index-repeat () in section A. Where it`s just saying that we may need to use index-repeat() for b17_main_purpose question. b17_main_purpose is asking about the purposes for growing potato ofsp. But b17 can only come if at A14_ofsp_5 one specified that he/she grew ofsp. Where could the problem be?. How do i use the indexed-repeat function in my case
case
