We have an xform that is preloaded with certain data using ODKCollect. One of the data items is a select1 Relationship to Head of Household, which is not prepopulated.
In certain cases, when we know beforehand that an individual is in fact the head of household, we'd like to prepopulate the select1 with that information and have the question be skipped entirely, presumably using relevant=false, which could be evaluated by using an invisible variable with its own binding that would also be preloaded.
I've noticed however that when our preloaded select1 is successfully preloaded, and by extension relevant is set to false using our invisible variable, the Relationship to Head of Household data is not included in the finalized form - the xml element disappears entirely. When relevant=true, the preloaded data is returned as expected.
Is it the case that, when an element is evaluated as relevant=false, the form dismisses the data element entirely, even if it is preloaded?
If so, have people found any workarounds to deal with this?
Any insights appreciated.
x-posted at https://groups.google.com/forum/#!topic/formhub-users/XwYWKeZw28o
as well
The relevant flag governs both whether the question is presented to the
user AND whether the data is saved and submitted up to ODK Aggregate.
This is dictated by the XForms spec
http://www.w3.org/TR/2012/WD-xforms20-20120807/#The_relevant_Property and
therefore will always be a limitation of ODK Collect.
This confounding of user interaction with data retention is eliminated in
the ODK 2.0 tools (e.g., Survey).
x-posted at
as well
One good workaround is to make the select1 readonly when you know that
relationship. That is, put the relevant logic into the readonly
attribute. This guarantees that the user can't change the answer when
they see that prompt and the data shows up in your final result.
On Fri, Jun 6, 2014 at 12:00 PM, Mitch Sundt mitchellsundt@gmail.com wrote:
The relevant flag governs both whether the question is presented to the user
x-posted at
as well
