emrstatusassessment.xls (39.5 KB)
Hello Osoti,
Please get attached of the XLS file. I had done the correction on the relevant column.
I had checked the file and Its works perfectly. If it works, do inform.
Regards,
Dinesh Dongolemrstatusassessment.xls (39.5 KB)
Hello Dnes_Dangol
Many thanks for the prompt feedback. It is working. Greatly appreciated
Cool Glad it worked for you .
Cheers.
Hello Dnes_Dengol
What else did you differently, I have tried to work on the same changes in the "relevant" column on my original template but its not uploading. Kindly support
EMR STATUS REPORT.xls (39.5 KB)
Hello Osoti,
Dependency cycles amongst the xpath expressions in relevant/calculate. Row no 18 which I had highlighted with the correction.
And there is spelling mistake in row no.8.
I had checked the form. And its working. Hope its works for you as well.
Please do inform if its work or not.
Regards,
Dinesh Dongol
EMR STATUS REPORT.xls (36 KB)
Hello Dinesh Dongol
That has been greatly helpful. So much appreciated.
Regards
Osoti Osoti
