Dear all,
Is it possible to add "relevant" conditions for questions which are inside
a repeat group?
I guess value names are incremented for each loop, which makes the relevant
conditions non working as the variable name in it stays the same.
Thanks for any help with this,
Tristan,
You can use relevance for questions inside a repeat, that should work
like other relevancies. If the relevance is outside the repeat and
interacting with questions inside the repeat, then things get
complicated.
If you have a specific issue you can reduce to a 2-3 question form
that you can share, that'd help us help you.
On Sun, May 28, 2017 at 6:28 AM, Tristan wrote:
> Dear all,
> Is it possible to add "relevant" conditions for questions which are inside a
> repeat group?
> "ODK Community" group.
