Relevant OR limits
I'm not sure what's causing this issue, but I have an idea for a way you
might be able to avoid it. Try breaking the formula up by using multiple
variables and binds with calculate attributes. I don't guarantee it will
work but it's the next thing I would try.
Hope this helps,
-Nathan
··· On Sunday, June 24, 2012 3:16:29 PM UTC-7, colind...@gmail.com wrote: > > Hi all, > > While creating a form for a health researcher I may stumbled into some > fundamental ODK/Android OS limits. > > Basically, I want to show one of two messages upon form completion > (Eligible and Not, roughly). In order to determine Eligibility, we need to > look at several fields that are entered into the tablet, including weight > and height, and then compare those to WHO averages (this chart > http://www.who.int/nutrition/publications/severemalnutrition/9789241598163_eng.pdf > ). > So, if I male is 45 cm tall, if his weight is less than 1.9 kg, he is > ineligible. If he is 46 cm tall, if his weight is less than 2.0 kg, he is > ineligible. Etc. > > I have a readonly field that says, 'Ineligible', and is displayed to the > user under the above circumstances, using ODK's 'relevant'. > > So far so good. > > However, there are about 200 conditions under which to show this readonly > (some nested), separated by ORs. When I get to about the 50th or, ODK will > no longer load the form (Unfortunately, ODK Collect has stopped). Logcat > shows a stack overflow. > > I assume this is an issue of trying to deal with so many ORs. Does that > seem correct to people? Is this an ODK or Android issue? Is there any way > around this? Maybe there's a better way to do these messages (rather than > ~200 ORs!)? > > CODE (simplified): > readonly="true()" relevant= > "(selected(/data/CES2_4, '1') > or > ( > selected(/data/CES1_1, '2') and ( > ( ((/data/MUAC_group/MUAC1 + /data/MUAC_group/MUAC2) div 2) > < 11) > or > ( (/data/MUAC_group/MUAC1 = '') and ((/data/CES2_1_a + > /data/CES2_1_b) div 2) < 11) > ) > ) > or > ( > selected(/data/CES1_1, '3') and ( > ( ((/data/MUAC_group/MUAC1 + /data/MUAC_group/MUAC2) div 2) > < 11.5) > or > ( (/data/MUAC_group/MUAC1 = '') and ((/data/CES2_1_a + > /data/CES2_1_b) div 2) < 11.5) > ) > ) > or > ( > selected(/data/CES1_2, '1') and ( > ( (((/data/height_group/height1 + > /data/height_group/height2) div 2) = 45) and (/data/CES2_2 < 1.9)) > or > ( (((/data/height_group/height1 + > /data/height_group/height2) div 2) = 46) and (/data/CES2_2 < 2)) > or > ( (((/data/height_group/height1 + > /data/height_group/height2) div 2) = 47) and (/data/CES2_2 < 2.1)) > or > ( (((/data/height_group/height1 + > /data/height_group/height2) div 2) = 48) and (/data/CES2_2 < 2.3)) > or > ( (((/data/height_group/height1 + > /data/height_group/height2) div 2) = 49) and (/data/CES2_2 < 2.4)) > or > ( (((/data/height_group/height1 + > /data/height_group/height2) div 2) = 50) and (/data/CES2_2 < 2.6)) > ... > >
I believe Android still imposes an 8K intermediate-storage (stack) limit,
and it is likely that you are hitting that limit. Nathan's suggestion is a
good one.
Hope this helps,
-Nathan
Hi all,
http://www.who.int/nutrition/**publications/**severemalnutrition/**
9789241598163_eng.pdfhttp://www.who.int/nutrition/publications/severemalnutrition/9789241598163_eng.pdf
ineligible. Etc.
So far so good.
~200 ORs!)?
CODE (simplified):
<bind nodeset="/data/CES_yes_**readonly" type="string"
or
< 11)
or
or
< 11.5)
or
or
or
or
or
or
or
I put part of your chart in Excel and extracted a fit to a 2nd order
polynomial. I just did 45 to 57 for -3SD and got the following:
y = 0.0063x**2 + 0.0887x + 1.8028
where x is the height and y is -3SD cutoff. This gives a really good fit.
You might try finding out the equation from which WHO generated this data.
··· On Mon, Jun 25, 2012 at 11:44 AM, Mitch S wrote: > I believe Android still imposes an 8K intermediate-storage (stack) limit, > and it is likely that you are hitting that limit. Nathan's suggestion is a > good one. > > Mitch > > > On Sun, Jun 24, 2012 at 10:15 PM, Nathan wrote: >> >> Hi, >> I'm not sure what's causing this issue, but I have an idea for a way you >> might be able to avoid it. Try breaking the formula up by using multiple >> variables and binds with calculate attributes. I don't guarantee it will >> work but it's the next thing I would try. >> Hope this helps, >> -Nathan >> >> >> On Sunday, June 24, 2012 3:16:29 PM UTC-7, colind...@gmail.com wrote: >>> >>> Hi all, >>> >>> While creating a form for a health researcher I may stumbled into some >>> fundamental ODK/Android OS limits. >>> >>> Basically, I want to show one of two messages upon form completion >>> (Eligible and Not, roughly). In order to determine Eligibility, we need to >>> look at several fields that are entered into the tablet, including weight >>> and height, and then compare those to WHO averages (this chart >>> http://www.who.int/nutrition/publications/severemalnutrition/9789241598163_eng.pdf). >>> So, if I male is 45 cm tall, if his weight is less than 1.9 kg, he is >>> ineligible. If he is 46 cm tall, if his weight is less than 2.0 kg, he is >>> ineligible. Etc. >>> >>> I have a readonly field that says, 'Ineligible', and is displayed to the >>> user under the above circumstances, using ODK's 'relevant'. >>> >>> So far so good. >>> >>> However, there are about 200 conditions under which to show this readonly >>> (some nested), separated by ORs. When I get to about the 50th or, ODK will >>> no longer load the form (Unfortunately, ODK Collect has stopped). Logcat >>> shows a stack overflow. >>> >>> I assume this is an issue of trying to deal with so many ORs. Does that >>> seem correct to people? Is this an ODK or Android issue? Is there any way >>> around this? Maybe there's a better way to do these messages (rather than >>> ~200 ORs!)? >>> >>> CODE (simplified): >>> >> readonly="true()" relevant= >>> "(selected(/data/CES2_4, '1') >>> or >>> ( >>> selected(/data/CES1_1, '2') and ( >>> ( ((/data/MUAC_group/MUAC1 + /data/MUAC_group/MUAC2) div 2) >>> < 11) >>> or >>> ( (/data/MUAC_group/MUAC1 = '') and ((/data/CES2_1_a + >>> /data/CES2_1_b) div 2) < 11) >>> ) >>> ) >>> or >>> ( >>> selected(/data/CES1_1, '3') and ( >>> ( ((/data/MUAC_group/MUAC1 + /data/MUAC_group/MUAC2) div 2) >>> < 11.5) >>> or >>> ( (/data/MUAC_group/MUAC1 = '') and ((/data/CES2_1_a + >>> /data/CES2_1_b) div 2) < 11.5) >>> ) >>> ) >>> or >>> ( >>> selected(/data/CES1_2, '1') and ( >>> ( (((/data/height_group/height1 + >>> /data/height_group/height2) div 2) = 45) and (/data/CES2_2 < 1.9)) >>> or >>> ( (((/data/height_group/height1 + >>> /data/height_group/height2) div 2) = 46) and (/data/CES2_2 < 2)) >>> or >>> ( (((/data/height_group/height1 + >>> /data/height_group/height2) div 2) = 47) and (/data/CES2_2 < 2.1)) >>> or >>> ( (((/data/height_group/height1 + >>> /data/height_group/height2) div 2) = 48) and (/data/CES2_2 < 2.3)) >>> or >>> ( (((/data/height_group/height1 + >>> /data/height_group/height2) div 2) = 49) and (/data/CES2_2 < 2.4)) >>> or >>> ( (((/data/height_group/height1 + >>> /data/height_group/height2) div 2) = 50) and (/data/CES2_2 < 2.6)) >>> ... >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitchellsundt@gmail.com > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en
** is "to the power of", so x**2 is x squared. Old notation. Sorry about that.
··· On Wed, Jun 27, 2012 at 10:31 PM, wrote: > Wow, nice. These are both good solutions (and reverse engineering the WHO formula is gotta be worth some bonus points!) > > I'm going to give both these methods a go and see which fits better. Gaetano, my math notation is a little fuzzy (it's been a while). What does the ** indicate in the formula? I tried the obvious things such as x^2 etc, but couldn't find anything that fits > > > Nathan, if I understand your suggestion correctly, I would have a bunch of variables that are never displayed, and then call them in the relevant for the Eligibility screen? > Maybe one var for each (/data/height_group/height1 + /data/height_group/height2) div 2) = XX)? > > Thanks again for these suggestions! > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en
