Relevant query
I'm created an ODK form that has a list of integer.
i.e.
How many brothers do you have? - integer
Based on them answering this and that figure being greater than 0 i want to
display:
How many older brothers do you have?
How many younger brothers do you have?
I can work out the relevant syntax to get this working any help appreciates.
the forms is an xlform
cheers
dan
Hi Dan,
If your original question was named "num_brothers" then you would need to
put a formula like this in the "relevant" column of the later questions:
${num_brothers} > 0
Regards,
-Nathan
ยทยทยท On Wednesday, February 20, 2013 5:31:58 AM UTC-8, Daniel Probert wrote: > > I'm created an ODK form that has a list of integer. > > i.e. > > How many brothers do you have? - integer > > Based on them answering this and that figure being greater than 0 i want > to display: > > How many older brothers do you have? > How many younger brothers do you have? > > I can work out the relevant syntax to get this working any help > appreciates. > > the forms is an xlform > > cheers > dan >
