I wanted to create an accompanying relevant question as below:
Where do you store yours savings?
ANSWER:
Bank
MFI
Cooperative
Home
Relevant question is:
If from a bank/MFI/cooperative, which one?
If bank/MFI/cooperative is ticked off, relevant question should prompt after. I'm having a problem with another choice though. If I tick off "home", the same relevant question is still prompted. How can I take out the relevant question when the choice is "home"?
I think what you're looking for is "not selected" as a relevancy. So, the follow up question should always be asked, except when they choose "home". In this case, the relevancy for your follow-up question would be:
You can use "or" or "and" in your formula to match more criteria.
In your example, you could use this formula in your relevant column:
selected(${employment},'employed') or selected(${employment},'selfemployed') or selected(${employment},'retired')
this would make your follow-up question show when they chose any of those three answers.
